Author Topic: p360 quick question  (Read 1127 times)
MasTequila
  • Last login:November 13, 2004, 12:07:53 pm
  • I'm a llama! Here me roar!
    • GameTruth
p360 quick question
« on: July 07, 2004, 07:20:01 pm »
Ok so I have looked at the instruction sheet about a million times and tried it as many ways as I can and I dont think I am putting it together right.  With the longer metal piece for a wood cp on I cant get the actuator at the bottom on with the e-ring. This must be an easy fix and I have just missed it so please help me out.
~Mas
« Last Edit: July 07, 2004, 10:54:19 pm by MasTequila »
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
Re:p360 assembly
« Reply #1 on: July 07, 2004, 07:47:46 pm »
It took me ten minutes to realize that I had to really press hard on the actuator because the spring is so strong.  I kept thinking that the groove was in the wrong place, but it wasn't.
In short, press hard.
MasTequila
    • GameTruth
Re:p360 assembly
« Reply #2 on: July 07, 2004, 10:10:42 pm »
Ah. Thanks.
MasTequila
    • GameTruth
Re:p360 quick question
« Reply #3 on: July 07, 2004, 10:55:20 pm »
What size screws should I use to mount and does it mount like the other happ joysticks or are the dimentions different, if they are does anyone know them offhand. Thanks in advance.
rdagger
« Reply #4 on: July 08, 2004, 12:47:58 am »
I've purchased several P360's and they all come with metal bushings that don't match the parts list.  The parts list describes 2 bushings (15-416400 .5" for wood & 12-408400 .156" for metal)  Instead they come with a single 5/8" bushing.  I think the manufacturer just assumes you will cut it to the proper length.  That's what I did.  You can compress the spring, but then it is rather difficult to insert and remove the "E" ring.  I just cut mine to 1/2" and it's much easier.
According to the instructions, if you have P360 questions you can call their support hotline:
800-230-P360 (M-F 8-5 MST)
