Author Topic: PCB or MVS?  (Read 3222 times)
talem
  • Last login:October 31, 2004, 12:08:24 pm
PCB or MVS?
« on: June 19, 2004, 07:41:43 pm »
Alright so i was woundering , is there a differance? I found Capcom vs SNK Jamma PCB and then i saw the MVS.. Whats the differance? or can i just get the Jamma PCB?
pointdablame
Re:PCB or MVS?
« Reply #1 on: June 19, 2004, 09:27:29 pm »
I am no expert in this, but from what I know, an MVS is a cart that will plug into a NeoGeo motherboard.  The motherboard is JAMMA and is on a PCB... so think of an MVS as a cart in a console video game system.
I guess if there are PCB's of the game, either Capcom or SNK made it as a standalone unit so that you wouldn't need the NeoGeo motherboard??
Again, this may be wrong, but I hope it helps... basically, if you bought just an MVS, you couldn't use it unless you had a neogeo motherboard.  I'd assume the PCB would work as any other  standalone PCB game would
first off your and idiot
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:PCB or MVS?
« Reply #2 on: June 19, 2004, 09:42:41 pm »
MVS stands for multi video system.  NeoGeo had a 1, 2, 4, and 6 slot MVS system.  Meaning it can handle 1, 2, 4, or 6 carts.  The games cam on carts, like a home console system did.
The MVS system is JAMMA compatible, to a point, the 4th button for each player is in one of the expansion pins on the JAMMA connector.
Note, these things go for some big bucks some times, especially the 4slot system.  They are a big collectors item.  And they are still being used today.  I heard the new Metal Slug 5 is pretty decent.
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
Re:PCB or MVS?
« Reply #3 on: June 20, 2004, 11:42:52 am »
This page illustrates the difference nicely...check out "Jamma vs. Neo Geo Wiring Diagram".  It's close enough (the biggest difference that you'd have to keep in mind is that MVS doesn't use -5V while JAMMA does).
I have a 4-slot MVS "board" sitting around and I constantly teeter between whether or not I should keep it or sell it.
talem
Re:PCB or MVS?
« Reply #4 on: June 20, 2004, 01:41:58 pm »
on the neo-geo.com boards thatll sell for like a couple hundred , i know a 2 slot went for about $200 on ebay.
mattv
  • Last login:June 10, 2022, 06:33:25 am
Re:PCB or MVS?
« Reply #5 on: June 20, 2004, 04:33:06 pm »
I'm pretty sure that Metal Slug 5 is PGM, not MVS
if you thought MVS was expensive wait till you see the crazy prices for PGM stuff, very similar system, just more modern.  Some of the games are pretty darn good tho!
More info on the PGM system here
http://www.klov.com/game_detail.php?letter=&game_id=8174
SirPoonga
  • Puck'em Up
Re:PCB or MVS?
« Reply #6 on: June 20, 2004, 11:35:34 pm »
Wow, I'd like one of those :)
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
Re:PCB or MVS?
« Reply #7 on: June 21, 2004, 12:08:12 am »
I got it from a friend of a friend who was moving and needed to get rid of it.  It was housed in a generic cabinet that had a blown monitor, and I got the whole shebang (cabinet (with coin door), MVS 4-slot system, controls) for $100.  Go me!  ;)
It's a quandry for me because it's barely worth it for me to have it hooked up since I can play all of the MVS carts that I own on my MAME cabinet.  And it's not exactly very economical from a gaming standpoint to keep buying more carts for the same reason.  But it's one of those things that I know I'd regret selling if I ever did.  Ah well...   :)
