Author Topic: Replace a PTC Thermistor  (Read 1835 times)
ranma
  • Last login:October 05, 2014, 08:44:01 pm
« on: June 10, 2004, 03:25:12 pm »
I have a monitor chassis that came without it's PTC, it was probable taken out because it wasn't working fine. I have a circuit schematic but it doesn't give the specifications of the PTC.
Do you know what should I buy?, it has to be three terminals. The degaussing coil is 27 ohm and the monitor is 220V.
Thank you.
Francisco
Hoopstar
  • Last login:June 12, 2004, 11:35:59 am
    • Hoopstars Garage
Re:Replace a PTC Thermistor
« Reply #1 on: June 11, 2004, 10:04:38 am »
I'd suggest the best thing is to get rid of the PTC and follow the article on Oscars website...
http://www.oscarcontrols.com/degauss/index.shtml
« Last Edit: June 11, 2004, 10:05:16 am by Hoopstar »
Ken Layton
  • Guru
  • Technician
« Reply #2 on: June 11, 2004, 11:17:35 am »
Contact the monitor manufacturer and order it as a repair part.
ranma
« Reply #3 on: June 11, 2004, 11:55:41 am »
Unfortunatelly, the manufacturer does not longer exist. The only thing I got from the guy that sold me the cab is a circuit schematic that doesn't specify a model.
ranma
« Reply #4 on: June 11, 2004, 11:58:25 am »
I'll try that, do you think I can do the same with the monitor coil itself?.
I was thinking of leaving the coil in it's place at first and try to degauss it that way, if that doesn't work, make an "external" degaussing coil.
