Author Topic: Those with a Happ rotary optical please read  (Read 8817 times)
MKL
  • Last login:January 10, 2003, 06:24:51 pm
« on: August 01, 2002, 02:49:15 pm »
I need to know which pin is which on the PCB connector.
the opto-pcb has the same circuitry of the trackball one but the layout is different...
Facing solder side with connector at the top, which pin is which from left to right?
Thanks in advance!
Skipp2k
  • Last login:July 24, 2002, 09:48:17 am
Re:Those with a Happ rotary optical please read
« Reply #1 on: August 02, 2002, 01:43:26 am »
Ya thats what I want to know too,
Looking at Ultimarc website under the opti-pac diy optical sensor page there is a diagram for a happ optical pcb.
Don't know if these are the same for the optical joystick, but most proberly are.
Talking about rotary joystick has anybody got it connected up to the i-pac with another joystick (non happ), so you can use any of them.
« Reply #2 on: August 02, 2002, 05:54:04 am »
Do you mean the pins are connected differently?  If the pins are the same, then I can look at my trackball & let you know.
Tho I'm sure someone will be able to tell you sooner :)
MKL
« Reply #3 on: August 02, 2002, 10:24:34 am »
This is Happ trackball (and spinner) opto-pcb:
http://www.ultimarc.com/images/happboard.jpg
That on the rotary joystick is different in that it has the connector on solder side and I fear the pin order may be reversed.
I took the pcb and with the aid of a multimeter I tried to figure out myself which pin is which. Pin 2 from the left (facing solder side with connector at the top) goes to two 150 ohm resistors and from there to two of the four sensor terminals, so this pin is likely to be the +5v one. If this is correct, then pin 3 will be ground. Anyway, I'd like someone to confirm this.
Happ part number for the opto-pcb is currently A052-1010-00. Mine has number A049-1010-00 because it's a NOS stick I won on ebay (for only $10!). However, I don't think it makes any difference...
Magnet_Eye
  • Last login:May 11, 2020, 09:26:19 pm
  • Feel the heat?
    • Web Hosting deals for BYOAC Users!
« Reply #4 on: August 03, 2002, 11:41:29 pm »
I have 2 Happs Optical Sticks. And YES, the pins in that image are correct.
Wires are:
Red: X1
Orange: GND
Brown: +5
Yellow: X2
I offer discounted WEB HOSTING to BYOAC members! Only $2.49 a month for a FULL FEATURED account! www.cloud9media.com
MKL
« Reply #5 on: August 04, 2002, 06:29:20 am »
Wires are:
Red: X1
Orange: GND
Brown: +5
Yellow: X2
Now this is really helpful, thanks!!!
I fail to see why they choose orange for gnd and brown for +5v  :o but anyway...
Magnet_Eye
  • Feel the heat?
« Reply #6 on: August 04, 2002, 09:10:00 am »
Yeah, tell me about it! horrible! it took me a while to figure it out back in the day..
anyway, glad I could be of assistance!!!!
:o)
« Last Edit: August 04, 2002, 09:13:33 am by Magnet_Eye »
apz
  • Last login:August 04, 2002, 12:16:09 pm
« Reply #7 on: August 04, 2002, 12:22:25 pm »
I think you have the gnd and +5v wires backwards.  I just got my joysticks last week and I just checked the wiring on them and the brown is the ground and orange is +5.  Perhaps they changed the colors at some point?
Magnet_Eye
  • Feel the heat?
« Reply #8 on: August 04, 2002, 09:16:01 pm »
yeah...who knows?! Email Happs. They have the answers.
warham
  • Last login:January 23, 2014, 12:14:03 pm
Re: Those with a Happ rotary optical please read
« Reply #9 on: December 06, 2009, 05:26:23 pm »
Q:    What are the wire harness pinouts on the Optical rotary Joystick 50-5619-00?    09/21/05
A:    These are the wire colors and pinouts for the loose end of the wiring harness.
RED Output A
BROWN +5V
ORANGE Ground
YELLOW Output B
warham
« Reply #10 on: December 06, 2009, 10:36:00 pm »
that last post is wrong... i got it right from happs site but its wrong.  I fried a board using it.    This is the correct wiring!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  notice brown is ground!!  not 5v like happs site says.
RED Output A
BROWN ground
ORANGE +5v
YELLOW Output B
DillonFoulds
« Reply #11 on: December 06, 2009, 10:55:17 pm »
I hope some of these guys are still around from 7 years ago. If not, i hope they built a time machine 7 years ago, so they could jump to today and read your solution. :S
mimic
  • Last login:July 20, 2025, 09:41:28 am
« Reply #12 on: December 08, 2009, 12:45:19 am »
And Stephen Hawking claimed there is no time tourists, I guess you proved him wrong warham!  :cheers:
phildo77
  • Last login:February 25, 2013, 02:18:45 pm
  • Building the massive "Game Grid." %95 complete!
    • Jack_Burtonn (AKA Phildo) on Video Gaming and Entertainment
« Reply #13 on: February 25, 2013, 02:18:45 pm »
This thread caused me to blow my boards....  I didn't read it through all the way.  :banghead:
I know its old but can someone either DELETE this thread, make the solution obvious or kill the offending posts?
"It's all in the reflexes!"
