Author Topic: I-PAC/4 4th player not working  (Read 2550 times)
mugopain
  • Last login:July 02, 2005, 12:08:34 pm
« on: April 13, 2004, 07:33:31 pm »
I tried running Guantlet and only could get three players working.  The 4th player coinstart is the only thing that works pertaining to the 4th player.
I have it hooked up via USB on Win XP PRO AMD 1.3gig.  The swith is set to the "Mame" and "USB" positions
I ran the test procedure and it seems to work fine for that.  I also tried it in an N64 emulated game "Mario Party 2" via 1964.099 and same results as Gauntlet.
I also have not tried to reprogram using the ALT setting.
Anyone have a clue to what might be wrong?  TIA
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re:I-PAC/4 4th player not working
« Reply #1 on: April 13, 2004, 08:08:02 pm »
  Did you open up notepad to see if the joystick and buttons are outputting anything?
  If I remember correctly, you need to 'turn on' the third and fourth players in MAME to get them to work the first time by programming them through the TAB menu.
/Steve
microwrx
  • Last login:July 06, 2008, 09:22:02 am
« Reply #2 on: April 13, 2004, 08:53:01 pm »
I got my 4 player cab finished on the weekend and went through MAME to stick all the 4 player games in a seperate game list and test them all.  I found what Steve has pointed to, you need to program up the button config in ALL of the 4 player games for player 4 in the TAB menu the first time you use them (everything except the player 4 coin as you have already found).  With every game I tried players 1, 2 and 3 were already pre-set up but all the inputs for player 4 were listed as NA.  Once this is done you'll be up and running in 4 player heaven (as long as you have 3 friends).
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #3 on: April 13, 2004, 09:48:21 pm »
Can't you simply remap the buttons in the "Input (general)" menu item in Mame's tab menu?  That would be a lot easier than remapping it for each individual game.
mugopain
« Reply #4 on: April 13, 2004, 09:48:23 pm »
Ok, kewl.  Thanks for all the help.  I will give it a shot.  Now if only I can kick my kid and her friends off to fix it.. :o)
Thanks again
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
« Reply #5 on: April 13, 2004, 09:53:50 pm »
quick questions here. Which is better the ps/2 I-PAC or Usb?
cdbrown
  • Bowowow
« Reply #6 on: April 13, 2004, 10:28:23 pm »
May I suggest you create a new folder within the mame/ctrlr folder
Copy the std.ini file from mame/ctrlr into your new folder
Rename this to default.ini
Edit it to include player 4 controls as they are actually mapped to joypad.  Also the 4th button on player 3 is mapped to a joypad button as well.
Then in mame32 change the Options-Default Game Option-Controllers and set My Controls to the new folder name.
Or mame change the mame.ini
### Input device options ###
ctrlr                 newfoldername
I've had troubles with the tab menus before.
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: April 14, 2004, 07:09:55 am »
I see a Pandora's box with this one.  Short answer is opinions vary.  Andy Warne has lately been favoring USB.  RandyT prefers PS/2.  (Both say for performance reasons apart from what their encoders support).
I have seen some performance issues with my USB trackballs and have heard some reports of problems (usually fixable) with the USB I-PAC that don't exist in PS/2.
My personal advice would be to use PS/2 for an arcade cab, and maybe USB for a desktop controller.
bigmoe
  • Last login:July 16, 2004, 04:17:54 pm
  • I forgot my mantra!
« Reply #8 on: April 14, 2004, 01:25:27 pm »
USB through an Optipac?
...and have heard some reports of problems (usually fixable) with the USB I-PAC that don't exist in PS/2.
I have one of the newest IPACS, hooked up through USB.  I haven't run into any problems playing 1-player fighters (which is the hardest I've pushed it).  Now if I only had friends, I could comment further...
What was that again?
Tiger-Heli
    • Tiger-Heli
« Reply #9 on: April 14, 2004, 01:57:47 pm »
Should have clarified - PC Trackballs (Glorified upside-down mouse) to USB through its own internal electronics.
Negativecreep0
« Reply #10 on: April 14, 2004, 03:46:55 pm »
me and the crew will be over tomorrow at 9, have a keg on tap............
mugopain
« Reply #11 on: April 14, 2004, 06:57:14 pm »
I am using Mame32 0.72  but i cannot find a "TAB" menu anywhere.  I see "Options->Default Options->Game Controllers.
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #12 on: April 14, 2004, 07:00:32 pm »
When you are in the middle of actually playing the game and you press "tab" an in-game menu will appear.
mugopain
« Reply #13 on: April 14, 2004, 09:14:08 pm »
Thanks!!  I got it all set up now.  I even re-programmed all the buttons.  Thanks again for all the help.
