Author Topic: Vertical screen setup  (Read 3239 times)
Benny
  • Last login:March 28, 2013, 01:37:31 am
  • Livin' the dream . . . one game at a time!
    • The Moonlight Mini-Arcade
« on: July 18, 2002, 12:08:43 pm »
How do I set up mame to run games like pac-man, etc. to run in "vertical mode" (i.e. the monitor tilted 90 degrees to utilize the full screen length)?
B.J.R.
bconpc
Re:Vertical screen setup
« Reply #1 on: July 18, 2002, 10:26:38 pm »
In the Windows version, you can edit the MAME.INI by going down to the Core Video Options and will see something called "ror" or "rol". By setting either one of the values to a "1" the games will rotate in that direction. In order to create the MAME.INI, go to DOS prompt and type in , mame -createconfig then edit the MAME.INI file
MrTomcat
  • Last login:October 09, 2002, 05:19:10 pm
« Reply #2 on: July 19, 2002, 08:56:16 am »
MAME -ror, or MAME -rol for the DOS version
Trimeister
  • Last login:July 23, 2002, 06:45:25 pm
« Reply #3 on: July 23, 2002, 06:49:26 pm »
once mame is loaded(.61) select Options then Default Options then choose your rotation under Rotation category.
I had the same issue but didn't realize it was that simple.
Thank goodness. Now I'm enjoying my games more because ot it.
Good luck.
Trimeister :D
