Author Topic: Rotating joystick for Qbert project  (Read 10110 times)
0 Members and 11 Guests are viewing this topic.
severdhed
  • RIP Dinosaur Hippo
« on: November 22, 2025, 11:52:51 am »
Hey guys, i'ts been a while since i've done anything here, but i'm getting the itch to build another cabinet. Early next year, we will be moving our I.T. business into a new building with more space. When I do, I plan on building a cabinet or two for us to use in our free time.  my 4 player pedestal cabinet is probably moving from my house to the office, but i want something dedicated for vertical monitor classics.    I plan on building a wall mount cabinet with a vertical monitor, 4 way joystick and just a few buttons. (still deciding if i want to put in a trackball for millipede/centipede or just continue to play them on the big one.
anyway, one of my all time favorite classic games is QBert.  Normally i just use an 8 way stick with a square gate and map the controls to use the diagonals, but sometimes this leads to missed inputs.  i really want a 4 way joystick mounted at 45 degrees to properly play this game, but building a dedicated qbert cabinet seems like a waste of space/materials.  So decided to engineer my own solution.  i fired up tinkercad and started 3d modeling a mounting plate that I could use to secure the joystick that would allow me to rotate it for qbert.  My first prototype finished printing this morning, so i threw it in a cardboard box and started testing.  so far, i'm quite pleased with it.  I was originally planning on using a Sanwa JLW stick, since they are my favorite, but i didn't have one with me while i was modeling at work yesterday. apparently i used the measurements for a JLF stick instead.   Fortunately I had some JLF sticks that i can borrow from another project.
basically i removed the metal mounting plate from the stick, and replaced it with a 3d printed circular plate. this has a lip on the bottom that rides in a groove on the back of the larger outsite mounting ring. there is a slot in the back right corner with a knob that can be rotated so switch the stick from normal 4 way mode, to 45 degree rotated mode for qbert.  i need to tweak the tolerances a little, and design some kind of retention system to help hold it in place at the two ends of the travel, but overall i'm fairly happy with how it turned out so far.    you have to cut a 4" hole in the wooden panel below for the body of the joystick to freely rotate.
what are your thoughts?  do you see anyting that i should change/improve?    Since the JLF stick is a little bit smaller than the JLW, i may try to reduce the overall size of each piece a little.  I normally cover my control panels in plexi, but i'd have to somehow route a curved slot in it for the knob to travel, i don't think the current slot is large enough for my flush trim bit to fit in it.  the other option i guess is to just surface mount the plate and skip the plexi.
Full plate mounted in cardboard box
closup of pacman knob
under side of joystick plate
underside of mounting ring
  • Last login:Yesterday at 11:25:03 pm
Re: Rotating joystick for Qbert project
« Reply #1 on: November 22, 2025, 08:35:47 pm »
That’s really cool and would have blown our BYOAC minds back in the day.
Extruder
  • Last login:Yesterday at 12:53:23 pm
« Reply #2 on: November 24, 2025, 05:38:06 pm »
This is a great project, nicely done!
Other than adding some kind of locking mechanism I don't see anything to add.
I'd be interested in the strength testing, though.
With the joystick acting as a lever, aggressive gameplay might exert angular force that may be beyond PLA's layer adhesion. High-impact PLA+ might be better, or even a nylon but most people aren't set up to print CF/GF nylons.
Are you sharing the files somewhere?
severdhed
« Reply #3 on: November 30, 2025, 10:37:43 pm »
i added a spring loaded detent notch on the ring to help hold it in place, i think i have the design close to being finished.  I did modify it to work with the JLW stick instead of the JLF...i just like the feel of that stick better. I still have a few tweaks to finalize the design. Once it is finished, i'll share the files for anyone that is interested.  I did increase the thickness of the disk and mounted it in a scrap of wood. some initial testing feels pretty solid, i think it will hold up fine.  this is printed in PLA+.  the main plate is 5mm thick, so it is fairly solid.  My plan is to make two more square plates and mount them next to each other in the cabinet.  I'm planning on adding a 2.25" trackball, and a few buttons.  Initially i was planning on 3 buttons, but i think two will be sufficient for the vertical classics that i plan on playing. i'm thinking of changing it to 2 buttons and a spinner in the middle plate.  here is a quick mockup of what i have in mind. i need some purple on the spinning joystick plate though, so i'm still trying to figure that out.
severdhed
« Reply #4 on: November 30, 2025, 11:30:09 pm »
here is an updated mockup with the spinner.  I'm using happ buttons for the main buttons, but im thinking of using the smaller 24mm sanwa buttons for start and pause/exit.
i'm not sure if i want them on the panel, or if i should make a small admin panel below the monitor...
Zeosstud
  • Last login:February 06, 2026, 10:32:55 am
« Reply #5 on: December 01, 2025, 07:26:33 pm »
Looks like a fantastic solution.. Enjoy!!
severdhed
« Reply #6 on: December 03, 2025, 11:07:02 am »
I Made some progress over the last two days.  The model has been updated to mount to the JLW stick. i thickened the mounting disk with a recessed area for the stick. this stiffened up the unit. i also added two notches in the disk that line up with a spring detent in the ring, this helps hold it in place at the two desired positions.
i added some decorative elements to the disk, and modified the pacman knob a little bit
I printed the middle panel for the buttons and spinner.  I'm quite pleased with how it turned out.  I had some 24mm black sanwa style buttons that i picked up for a previous project that ultimately went a different direction. these worked well for the start and pause/exit buttons.  I wasn't sure how well the multi color 3d printing would turn out when used for labels and decoration, but it looks pretty good. Everything was printed face down on a textured plate so it has a very nice finished texture to it.  There will still be a 3rd panel to the right, but i have to wait for the trackball to arrive so I can design the plate to fit it. I only had a 3" trackball on hand which was just too large for this project.  I ordered a 2.25" trackball/spinner combo from amazon, i'm optimistic that it won't suck, but it isn't going to be delivered for a few weeks.  that will give me time to find and cut the actual wooden under panel to the correct size so that when it does arrive, i'll have the real panel ready to go.
the only downside to this design is that my hand rests on the spinner knob while using the buttons. it ins't horribly uncomfortable, but it is a little weird.  i don't know how to get around that though unless i just ditch the spinner entirely.   There are only a few spinner games i'd like to have on here and they certainly arent' a deal breaker, but i haven't had a spinner in my cabinet in many years, i'd like to have the option.  I pulled the turbo twist spinner out of my cabinet at work to test it with this panel, but i will swap it out with the new one when it arrives.  I thought about moving the spinner to the left side and putting the buttons on the right, this would possibly make it more comforable to rest my hand while playing joystick games, but just like the trackball, i like to use the spinner with my right hand, which would make using the buttons difficult for the spinner and trackball games.
i guess i could move the spinner towards the back of the panel, but then i'd have to relocated my start and pause/exit buttons.
I also printed a new dust washer for the joystick. the stock one was about 2mm too small to completely cover the screw heads.
« Last Edit: December 04, 2025, 09:20:49 am by severdhed »
« Reply #7 on: December 03, 2025, 07:29:32 pm »
Nothing to add besides “this is really cool.”  Carry on, sir.
  • Last login:February 04, 2026, 05:27:25 pm
« Reply #8 on: December 05, 2025, 04:38:46 pm »
That is super cool and a clever way for anyone to control it.
severdhed
« Reply #9 on: December 06, 2025, 12:01:36 pm »
Waiting for my trackball and spinner to arrive on Thursday, so I decided to model a quick mock-up of the cabinet.  The speaker grills and marque will also be 3d printed. The letters will be 1mm thick so they will light up with some LED strips.
The gray panels will be MDF covered in carbon fiber vinyl. I'm not sure if I'm going to paint the purple sides, or vinyl wrap those as well.  I haven't decided of in going to cut a monitor bezel from MDF, or mask and paint some plexiglass instead.
skr
  • Last login:Yesterday at 04:23:52 pm
« Reply #10 on: December 07, 2025, 11:14:30 am »
Ver nice print indeed, the multicolor thing turned out awesome!
Which printer are you using?
severdhed
« Reply #11 on: December 07, 2025, 01:14:01 pm »
Thanks. I'm using the Anycubic Cobra 3
Xiaou2
  • Last login:Today at 12:20:22 am
  • NOM NOM NOM
« Reply #12 on: December 09, 2025, 08:03:29 pm »
Do a test, and try mounting the Spinner to the Front of the Cabinet  (mounted horizontally, like a volume dial)
Another option, is a Spring Mounted mechanism... where you can raise and lower the spinner... by pressing
it.. or using a mounting assembly that can be raised and lowered  (which might be similar to the lever
on your Qbert stick... just in a different vector)
To play games like Tron, Mad Planets, and more... you would want a small fire button on the top of your stick
I believe Ive seen ball-top joysticks, that have a small button on top
Check out the Wico Command joysticks.  They made balltops and long bat joysticks, that have the top mounted button
These also have a Rubber Centering Grommet, making them feel much better for Classic Arcade games
Additionally, at least ONE of your buttons should be a Pinball Leafswitch Button (long travel leafswitch).  These
are excellent for Rapidfire games, like Halleys Comet, Asteroids Deluxe, and Galaga.  You can "Feather" them on/off
by Vibrating your finger.. which makes them fire extremely fast.. while also reducing finger Fatigue by a factor
of 1000 (compared to microswitch buttons)
As for the Trackball...  Having it that close to the monitor... may lead to some hand injuries, when trying to roll it
forwards fast.   Some time ago, I came up with the idea for a Flip-Out trackball assembly.  When the trackball flips
out from the Control Panel... it would make the Trackball be several more inches away from the monitor.. giving
you a lot more space.
You might look into making a Flip Out Trackball module, to give you the additional room to spin it at full speed,
without hitting the monitor
Edit:   There is another possible solution to the Trackball issue..  where you could make the entire Control panel slide
forwards away from the Main Base.  You would need to devise a locking mechanism, to prevent it from sliding
freely, once its slid away from the main base.
You would also want to remove that raised LIP on the edges of the control panel.. as otherwise your hands
will smash into it, when rolling the ball to the right
« Last Edit: December 09, 2025, 08:11:02 pm by Xiaou2 »
Xiaou2
  • NOM NOM NOM
« Reply #13 on: December 09, 2025, 09:25:17 pm »
Example Mockup
In this example... you have a Balltop with the top Button added
A flip out Trackball
Four Buttons (top left button = A Pinball Leafswitch button)
Pinball Buttons on Both sides of the Cabinet, for playing Virtual Pinball tables
A spinner on the Front of the Panel
A possible alternative spinner location, on the Side of the cab.. though, this would
probably have to be raised higher up  (my mistake)
And, add one Bass Shaker Transducer in the cabinet, for a subwoofer like vibrational effect
(even greater vibrations, without the air movement.  they sell them at Partexpress)
And finally... If one does the Flip Trackball method, it would be best to round all of the corners,
to prevent any hand scrapes
You would also need a small post or Lip to pull the Trackball up
severdhed
« Reply #14 on: December 15, 2025, 08:29:44 pm »
thanks for the feedback.  i have no need for joysticks with buttons on them, tron doesn't interest me. this is a vertical classics cabinet, not a do everything cabinet. i like the feel of microswitchh buttons. i love the JLW joystick. i had a wico stick once that came in a DK cabinet, i hated it. it was so stiff and hard to move, i want to play games, not get a forearm workout.  i have no desire for pinball games. the spinner will be fine where it is. the trackball will also be fine where it is. it is only really there for centipede and millipede.   i have a trackball in my pedestal cabinet if i want to play golf or bowling games, but i very rarelly do.
i plan on having about 30 games on here that are actually good. i've built quite a few cabinets already so i know what i like and what i don't when it comes to controls.
anyway, my trackball arrived on friday, so i modeled the last panel, it fit perfectly on the first try!
i made a new test panel so i can test everything while i set up the pc. i'll probably hold off building the cabinet until spring at this point.
Xiaou2
  • NOM NOM NOM
« Reply #15 on: December 15, 2025, 11:24:02 pm »
 I used to have the same Opinion as you... and so when I became a Manager at an Arcade (in the 90s),  I sadly started replacing
all leaf controls with Microswitches.   I got complaints immediately... even by one of my Staff, whom refused to play Galaga
anymore... because of it  (it was one of his favorite games, that he played daily).
 I was shocked at first... as I couldnt understand why he would be so against the Microswitches.  Especially because the leafs
often had to be cleaned.. and even sometimes adjusted.
 He revealed that it was much more Fatiguing to keep firing a microswitch button, compared to a leafswitch button.  I didnt really
understand how that could be... until some time, much later...   And this description below,  reveals why:
 The thing about Leaf controls... is that you dont have to move them to the full travel length, to get them to Activate
 With a Pinball style leaf button... you can fire like 3 times faster... and can maintain maximum fire rate.. for over an hour
without ANY fatigue.   You cant do that with a Microswitch button.  With a microswitch, you will be fatigued in about 3 minutes tops...
and you wont be able to maintain maximum speed.
 But here is the problem... Most people are ignorant about how far you have to press a Leaf Button.  They press it until it bottomed out,
which is like 40% too far.  The two leafs touch, at about half the travel of the button.  Once you get them to touch... all you have to do
is lightly Vibrate your finger, to get the leafs to toggle on/off (within the distance of like a single thickness of paper).  It takes no effort
at all.
 Leaf Sticks are a similar.  The rubber resistance gets strong near the very end of the travel of the stick.  If you choose to use heavy
power / force.. you can keep the stick at the very edges... but you dont really need to press that far to move your character / change
directions.
 Then why would they have that additional travel?   That is to prevent Damage to the stick..  and to reduce Impact Vibrations,
into your hand.   If you suddenly jolted the stick to its maximum extremes.. out of fear of being hit... the rubber Vastly
reduces the impact of the stick to the restrictive side-walls.
 For a game like Robotron... these sticks are a Necessity,  because in that game, you are escaping death by a mere pixel or two.. every
two to three seconds.   You need the smallest amount of activation distances... so that you can be able to reverse directions
faster (to juke / avoid running into a projectile)
 A Happs super Stick, doesnt even compare.   The super has a much longer travel before the microswitches activate.  That results
in a longer time delay... and often leads to you getting Hit... instead of avoiding the projectile.
 So... this is a common issue, with people (like my former self), that were simply not using Leaf Controls, as they were Intended
to be used.   And once I learned how to operate them properly... my performance and comfort levels.. FAR exceeded what I could
do with modern Microswitch based controls.
 Btw - Have you tried the game  Mad Planets ?   If there was ever a case for having a top mounted fire button.. so be able to be
used with a spinner...  I think that game would be the deciding point.
 Tron and Mad Planets are Both Vertical games.  Maybe you are thinking about  "Discs of Tron"  which is Horizontal.
 Tron is a little Frustrating, because the lightcycle stage can be brutally unfair... unless you memorize certain patterns.
Its still a very fun game... despite this.  But something like Mad Planets, does not suffer from that unfair balance issue.
 There might be a few others, where a top button would help... but I cant recall at this time.
 Anyway, its your cab... so do as you please.   But I would highly advise learning how to "Feather" a leaf button... and to
learn the true Joys and benefits of leaf controls.  As Once you figure them out... you wont want to go back to using
microswitches on classic games.   Only exception, are Fighting Games, with require Microswitches.
Extruder
« Reply #16 on: Yesterday at 12:53:23 pm »
Are you sharing your files somewhere? This is a great solution and I'd love to try this is my cab.
