Author Topic: Suzo Happ 3” trackball with bad green boards?  (Read 228 times)
Bloodta
  • Last login:May 05, 2024, 01:29:20 am
« on: April 26, 2024, 09:49:35 pm »
I just bought a Happ 3” trackball for exclusively playing Golden Tee. It’s P/N 56-0113-00K/(55-0302-00). Can it be upgraded to “work” well with golden tee?
  • Last login:Today at 12:03:29 am
Re: Suzo Happ 3” trackball with bad green boards?
« Reply #1 on: April 27, 2024, 02:01:29 am »
Yes, you can fix the backspin problem that many people have complained about by replacing that Happ trackball encoder.
- If you can, return that trackball and exchange it for a model that has Happ "Red Boards" and an arcade-style molex harness.
- If you can't exchange the trackball, upgrade the two green boards to Happ "Red Boards".  (P/N A052-1011-00)
To convert the quadrature waveforms from the "Red Boards" to USB mouse movements, use an OptiWiz3 and the Trackball Cable for Opti-Wiz "No-Solder" from GGG.
Bloodta
« Reply #2 on: April 27, 2024, 02:07:50 am »
Thank you very much.
