Author Topic: Power button for Dell Optiplex 3020  (Read 3631 times)
Bloodta
  • Last login:March 29, 2025, 09:34:13 am
« on: April 22, 2024, 12:51:10 pm »
Has anyone successfully added an arcade button to power on/off a Dell Optiplex 3020? I’m stuck.
  • Last login:Today at 10:43:51 am
Re: Power button for Dell Optiplex 3020
« Reply #1 on: April 22, 2024, 02:56:31 pm »
Can't you just wire a pushbutton to the pins on the motherboard?
Bloodta
« Reply #2 on: April 22, 2024, 05:34:25 pm »
I have no idea what I’m doing.
jmanderson10
  • Last login:April 22, 2024, 05:53:18 pm
« Reply #3 on: April 22, 2024, 05:38:28 pm »
I’m not an expert. But this is what I’m going to use. Basically open your computer up and replace the existing power switch with this. Then install on the cabinet somewhere.
https://a.co/d/fSnKgBP
Bloodta
« Reply #4 on: April 22, 2024, 07:26:07 pm »
Hey, awesome, this may be exactly what I needed.
Phreakwars
  • Last login:August 18, 2025, 05:07:23 pm
  • Waka-Waka
    • forum.arcadecontrols.com/index.php/topic,146325.0.html
    • My Facebook Page
« Reply #5 on: April 23, 2024, 01:36:46 am »
The 3020 uses a proprietary power lead that is smaller than a typical DuPont connector. You can get an adapter to use a regular power button from here: https://store.harbinrepairs.com/index.php/product/dell-optiplex-390-3010-3020-front-panel-header-adapter-3pc-kit/
Bloodta
« Reply #6 on: April 24, 2024, 12:14:07 am »
I do have the ultra small form factor optiplex 3020 if that matters.
Warborg
  • Last login:May 23, 2025, 07:14:48 pm
  • Personal text? Nah...
« Reply #7 on: July 06, 2024, 03:53:46 pm »
I have some SFF Lenovo systems and the switch is mounted directly to the mobo...  I ended up just soldering a couple of leads to the pins of the switch and running them out of the case to an arcade button.  On top of that, you can also enable "Power on after power loss" in BIOS and can just switch off/on the power strip for the system to power it up as well.
