Author Topic: Skee Ball Model H Beacon help  (Read 4092 times)
ragerrl
  • Last login:December 28, 2023, 01:48:50 am
« on: December 26, 2023, 09:29:02 pm »
Hey Everyone!
I recently got a 13’ Skee Ball Model H.  It does not have the beacon….the mount is there but the beacon is MIA.  I’d like to add one back on, but I’d like to wire it back in the proper spot.  There is one plug coming off the power supply that isn’t hooked up to anything.  I’m not sure if that is the spot or not.  I have looked at the schematic but to be honest I’m not really confident reading it.  If you have a model H could you please take a look and let me know.
  • Last login:Today at 12:47:03 am
Re: Skee Ball Model H Beacon help
« Reply #1 on: December 27, 2023, 01:24:49 am »
I don't have a Model H, but I can help you with reading the schematics.
The beacon is called flasher in the schematics.
https://arcarc.xmission.com/PDF_Misc/SkeeBall%20Model%20H%2002.pdf
Here are some embeddable images of the Model H Deltronics Manual from UncleT's site.
http://unclet.arcadecontrols.com/SkeeBall/SkeeballMain.html
Image 7 shows that the flasher connects to P23.
P23 then connects to wiring harness J23 on image 4.
- Pin 2 goes to the 3A slow blow fuse. (A/C Hot wire)
- Pin 1 goes to P22/J22.
J22 is wired to the power supply board as shown in the layout illustration on image 6.
