Author Topic: Gun4IR + Rambo Arcade Unit - LED Power Help  (Read 542 times)
clac
  • Last login:September 16, 2023, 05:26:48 pm
« on: September 06, 2023, 10:39:07 am »
Hey people!
I need some help before I have another strop!
I have a Rambo aracde unit and putting in a 55 inch TV
It seems that I am mm short of adding the LEDs for Gun4IR. Especially to the top and bottom
A - Does anyone know of a way to power the built in LEDs? Perhaps to be plugged into a normal plus socket or usb would be preferred
The model of the LED Boards is LED BD Gun Sense HOD 838-13145-02
B - I would assume there is no way to change Gun4IR software to work with the 8 LEDs surrounding the screen? I imagine this task might be too much
If I can power the LEDs. I could use them for the top and bottom LEDs for gun4IR. Hopefully I can just squeeze the LEDs onto the sides of the TV ok
I have added a photo of the LED board and also one I found online, which might give better details
I found a site (http://solid-orange.com/1620) suggesting it is a 6-pin JST XH connector........ if that helps
Thanks!!
