Author Topic: Need help with finding a chassis for my tube please  (Read 866 times)
bigncrazy1980
  • Last login:April 12, 2024, 01:22:31 pm
« on: June 01, 2023, 02:06:28 am »
I picked up a 27" tube Phillips model A68AHD32X R27GYWH 330290-32. I'm not sure what numbers are relevant so I just posted all the numbers on the paper on the back of the tube. The yoke measurements are 1.4 and 6.8. Could anyone tell me what Chassis I need to put this in a standard resolution game? If it matters, its going into a marvel vs capcom dynamo cab. I did not get a chassis with the tube at all and I'm completely in the dark on what one I should order for it.
bigncrazy1980
Re: Need help with finding a chassis for my tube please
« Reply #1 on: June 01, 2023, 06:20:09 pm »
I was told that a k7000 should fit this. Anyone have an idea?
bobbyb13
  • Last login:Today at 02:37:12 am
« Reply #2 on: June 02, 2023, 12:18:56 am »
I have built a few monitors using tubes that size with similar yoke values.
The K7000 series definitely is pretty versatile that way if you can find one built for a 25" plus tube.
They have flybacks that produce slighty higher voltage than the 19" ones.
More recent multi-res or multi-sync chassis are pretty broad acceptors of yoke values also.
I am using the ones below right now in a few machines.
Sharp Image 727r ds
Kortek 2938
Orion 2903
I'm sure there are more but those I know for a fact work.
bigncrazy1980
« Reply #3 on: June 02, 2023, 03:59:51 am »
Does anyone know where I could locate a k7000 chassis? people on ebay think they got gold lol
bobbyb13
« Reply #4 on: June 02, 2023, 04:48:49 am »
Already rebuilt chassis for tubes that size are harder to find than ones for 19s so therefore more $$.
Try klov
Zebidee
  • Trade Count: (+9)
  • Last login:April 25, 2024, 06:33:53 pm
« Reply #5 on: June 02, 2023, 10:31:41 pm »
The Sharp Image chassis are great, if you can find them. I once matched an SI with a 27" Philips tube and it was the clearest 15khz picture I've ever seen on an arcade monitor. Good tube, good chassis, great monitor. It was for a mate so don't have it anymore.
