Author Topic: Question about Repairing Famicom Joystick  (Read 1082 times)
Chris2
  • Last login:September 28, 2024, 09:56:40 pm
  • Servin' up Bacon.
« on: March 28, 2023, 12:13:46 am »
Hello all,
I am trying to restore a Famicom ASCII Stick, which is an arcade controller for the famicom. The stick uses Matsushita 76515 microswitches, and with a little research I've found that this was replaced years ago by the Panasonic AM5 series (specifically, the AM51661A5). Link I pulled this info from: https://forums.arcade-museum.com/threads/has-anyone-here-ever-replaced-the-microswitches-in-an-snk-ls-30-rotary-joystick.297455/
Perhaps I am lucky that it is at least well known for being in Ikari Warriors sticks.  :)
However, that part appears to now be obsolete as well, at least according to the Mouser page for it.
What can I do to replace it?
"Do you like Huey Lewis and the News?"
lilshawn
  • Last login:December 04, 2025, 08:10:20 pm
Re: Question about Repairing Famicom Joystick
« Reply #1 on: March 28, 2023, 12:43:58 pm »
it really is just a standard microswitch.
https://datasheet.octopart.com/AM51610A59-A-Panasonic-datasheet-41394079.pdf
if you are really concerned about button press forces, the other suggested part out there is a AM51661C5.. and it has an actuation force of 3.92 newtons. just find another microswitch from another brand that has the same actuation force and bob's your auntie.
