Author Topic: Spray-paint and aluminum?  (Read 16724 times)
Trebeck
  • "The Arcade" - Build #4
« on: October 12, 2021, 11:01:21 am »
Hey all,
I have a marquee holder from Home Depot that is an "L" shaped piece of aluminum.  Can I spray-paint these black or is there a better way?
I don't want to have it easily scratch off on me.
Thanks,
Beck
LTC
  • Last login:June 02, 2026, 11:55:37 am
Re: Spray-paint and aluminum?
« Reply #1 on: October 12, 2021, 09:46:25 pm »
I used vinyl wrap to cover up mine, but with proper prep, spray paint should hold up.
« Reply #2 on: October 13, 2021, 05:22:40 am »
Spray paint is standard (if not using actual plastic marquee retainers).
Use primer if you are concerned about ot being scratched.  Project farm on youtube has done some paint durability tests if you want to watch those.  I don't recall which came out best for scratch resistance.  IIRC Rustoleum 2X did pretty well.
MartyKong
  • Last login:June 03, 2026, 04:05:00 pm
« Reply #3 on: December 29, 2022, 02:59:13 pm »
Another idea is to use plastic clear painters edge guard. This is designed to protect wall corners but since it's clear you can spray the back of it which will show your color but still be protected from  scratches. Just another idea.
