Author Topic: Arachnid 6300 6 plus 2. Throw/remove lamp socket  (Read 3911 times)
Shoestring
  • Last login:August 03, 2021, 01:04:07 pm
« on: July 31, 2021, 12:34:08 pm »
 Hi all
  Hope to find some information.
  I just got a 6300 super 6 plus 2
   I drill out the locks to get into the guts of everything.
Found the 12 volt wire off of the replacement power supply.
 Made the connection and it’s working to some extent.
I’m missing 2 of the lamp socket’s for the remove and throw lights
( 2182-D Lamp ) I replaced the other lamp with the correct bulbs.
But have not found a part number for the lamp holder.
   Then there’s the monitor that is rolling- top to bottom-
I may have to have a local arcade guy check out the monitor as it will be quicker and I’ll ask lots of questions.
  I have not found a dip switch for vertical or horizontal stability
Only one for Focus.
   Thank for any info.
