Author Topic: Does AMD Ryzen 3 3200G work with crt_emdriver?  (Read 2866 times)
punkysuen
  • Last login:February 12, 2022, 12:25:37 am
« on: February 23, 2021, 01:02:07 am »
I look at the GPU list, see that AMD Ryzen 5 2400G and AMD Ryzen 3 2200G are supported.
However, they may be too old to be found in my local stores.
I can only find AMD Ryzen 3 3200G.
Have anyone tried?
Thanks.
Phreakwars
  • Last login:June 24, 2025, 01:58:29 pm
  • Waka-Waka
    • forum.arcadecontrols.com/index.php/topic,146325.0.html
    • My Facebook Page
Re: Does AMD Ryzen 3 3200G work with crt_emdriver?
« Reply #1 on: February 23, 2021, 04:21:13 am »
If the 2200 and 2400 both work, I see no reason at all the 3400 (3200) won't. What I wanna know, is will it work with (I'm guessing probably) the 4750g.
« Last Edit: February 23, 2021, 04:23:29 am by Phreakwars »
Substring
  • Last login:July 06, 2025, 02:23:53 pm
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
« Reply #2 on: February 23, 2021, 02:25:28 pm »
why bother, it doesn't support interlace, you're quite limited
Calamity
  • Moderator
  • Last login:July 01, 2025, 01:29:14 pm
  • Quote me with care
« Reply #3 on: February 23, 2021, 04:02:55 pm »
The Ryzen 3000 APUs are not supported by most recent available CRT Emudriver, that dates from 2018. A new version based on current AMD drivers would support these APUs, but I don't have a schedule for this. The problem is Windows drivers don't have support for interlaced on this hardware, so it's rather pointless. Although 15-kHz low resolution modes work, lack of interlace means no usable 15-kHz desktop.
Any chance of using this new hardware will mean Linux.
Have anyone tried?
Thanks.
Steps to create a log:
punkysuen
« Reply #4 on: March 06, 2021, 03:01:48 am »
Thanks for all replies!
dmckean
« Reply #5 on: March 06, 2021, 03:37:03 am »
I don't think lack of 480i is a total deal breaker. It would be nice to have a frontend that works with 240p better.
Calamity
  • Moderator
« Reply #6 on: March 06, 2021, 05:20:58 am »
I'm with you. But having tried Windows 10 at 240p, I can say it's unusable even for me. For instance, you can't even see the password on the logon screen. It's theoretically possible to setup everything first using a normal monitor, then tweak it remotely later on.
