Author Topic: Arcade 1UP - Countercade Tablet PC Multigame - MAME MOD  (Read 5702 times)
negative1
  • Last login:February 08, 2025, 08:27:09 am
« on: January 13, 2020, 03:51:39 am »
Arcade 1UP - Countercade Multigame-mod
So, I got the Dig Dug countercade, but wasn't
happy with the controls for Dig Dug 2. Also,
Dig Dug was the Japanese settings, which is
5 men only, which makes it much harder to
get to 1 million and killscreens.
Anyways, I bought the LVDS adapter, but haven't
been able to get it to work quite right, so
I've given up on that for now. My plan was
to add a pc, or small computer to it, for
using MAME for multigames. Or to input
from a game console.
Issue - Small screen size, actually it isn't
too bad, when sitting in front of it, but it
is very small when playing horizontal based games.
Solution - New Screen
Issue - Bad emulation, and controls
Solution - Better PC, and alternate controls with joystick,
trackball and spinner
Issue - Mono sound (loud though)
Solution - Stereo Sound
Issue - Poor screen angles and colors
I ended up using a Fujitsu 13 inch tablet PC which
I had not being used currently.
Its a Core 2 Duo, 1 Gig ram, 80Gig hard drive.
So tons of horsepower, and space for many
emulators, and ROMS.
This solved all problems at once, and also added
pen input to the screen, so no keyboard is needed.
The tablet PC has 2 usb inputs, firewire, audio in,
audio out, VGA out, microphones.
- 1 usb used for controller(s)
- 1 usb used for keyboard or HUB
Resolution : 1024x768 32 bit color
Networking : Built In
Battery    : Up to 4 hours with expanded battery
YES, it can be 'portable', and does not need to be plugged into wall socket.
Bezel - Too large on original
Solution - Replaced with Black Plastic Board cut to allow screen to show.
Total Price  - Tablet ($50-150 spent several years ago - many can be found on EBAY)
             - Bezel  ($5 spent at Art supply store)
Keyboard (already had spare)
Joystick, Mouse, Trackball, Spinner (already owned).
So technically it cost me $5, since I owned all the other parts.
Game notes:
- Software
MAME 0.106 for testing.
I can upgrade to much later versions for other
games, but I was trying to show Arcade 1UP ones,
and mostly vertical ones.
OFFICIAL CURRENT Arcade 1up Games
Dig Dug - Slight glitch in sound, but can play Atari Roms, besides Namco, and alter player settings.
Dig Dug 2 - Perfect emulation of both versions, and superior controls, since 2 buttons are on the
            right side mapped correctly
Centipede - Works great, haven't put in correct settings for trackball
Missile Command - Did not Test
Space Invaders - Works excellent, need to tweak settings for correct sound
Space Invaders Color - Works excellent, need to tweak settings for correct sound
Pac-Man   - Did not test, expect it to work perfectly
Pac n Pal - Tested, works perfectly
Galaga   - Tested, works perfectly
Galaxian - Did not test
PROPOSED BUT NOT RELEASED
Defender - Works, but have to map controls correctly
Joust    - Works perfectly
Ghosts N Goblins - Works perfectly
GAMES I LIKE, BUT NOT OFFICIAL
Galaga '88 - Excellent game in the series
Joust 2    - Excellent Vertical oriented game, very tough
Pac-Man plus - Tested, works perfectly
Super Pac-Man - Tested, works perfectly
Pacmania - Tested, works perfectly (will have a separate gameplay video too)
Final notes: You can see the tablet green LED's, but when playing
they are blocked by the Bezel. Also in the video, the left side
appears to bent slightly, but from the front view, its fine.
I need to tweak the software somemore, and add some more ROMS.
I don't care about frontends, and MAME GUI works fine for me.
Any questions about the games, let me know.
later
-1
lilshawn
  • Last login:Today at 06:18:16 pm
Re: Arcade 1UP - Countercade Tablet PC Multigame - MAME MOD
« Reply #1 on: January 13, 2020, 12:41:11 pm »
if you plotz your proposed LCD panel part number into google usually you can find a datasheet that will tell you the panel's operating voltage, the native resolution, and the data bit format you need to set/order your LVDS board to drive it.
I usually buy LVDS boards that have jumpers to set everything, not the pre-programmed type you typically find on ebay. they are a little harder to find, but the "MT6820" and the  "MT561" are both very good boards that work with a very wide variety of panels (has onboard regulation and will drive 3.3v and 5v panels with only a 5v input.) though only has VGA input and I feel you are looking for one with HDMI for a pi or something.
Something to roll around in your head anyways.
negative1
« Reply #2 on: January 13, 2020, 01:21:18 pm »
I bought an early one, so it may not have been compatible.
That's ok. I'm repurposing the original PCB, screen, and bezel, into a mini-cocktail table unit probably.
I like to tinker with stuff, and sometimes stuff works, and sometimes it doesn't.
In this case, using the Tablet PC was a much better solution, with many advantages.
Sure I lose the dedicated bezel, but it was pretty huge anyways.
later
-1
JDFan
« Reply #3 on: January 13, 2020, 01:39:40 pm »
There is this kit for $20 shipped that has everything needed to hook them up to the rpi- https://www.ebay.com/itm/Arcade1Up-8-LCD-Video-Driver-Converter-Board-add-HDMI-VGA-Countercade-Counter/163888094287
OR this type should work also but doesn't have the VGA to HDMI adpater (like the ones you mention with dips for setting program) IF you use their coupon they are $6.18 shipped from china - https://www.aliexpress.com/item/32280436798.html?aff_request_id=3bbee4e795054b2791f0b0c4c6da57bf-1578940613629-06691-dTi0zhbE&aff_platform=link-c-tool&cpt=1578940613629&sk=dTi0zhbE&aff_trace_key=3bbee4e795054b2791f0b0c4c6da57bf-1578940613629-06691-dTi0zhbE&terminal_id=12cf96166a7b40879af78f3186dec12b
  • Last login:Yesterday at 08:37:44 pm
« Reply #4 on: January 14, 2020, 07:28:04 pm »
Very cool...
some build pics would be nice. If the bartops can come in around the $99 price point, that's a great candidate for a bartop build.
JDFan
« Reply #5 on: January 15, 2020, 09:53:53 am »
Very cool...
THe v2 release is going to have a MSRP of $99 - they've redesigned with a 7" screen instead of 8" and made it more proportioned to get to the lower price point - so not sure how much room there will be inside but should still make a decent starting point and with the artwork included at that price it makes for a good starting point with no need to Paint,sand,paint,sand,paint !
