We are just talking past each other at this point, and your defenses seem to be in overdrive. When a claim is made that X is as good or even better than Y relative to a certain specification, it should probably be expected that the claim will be called into question, and in cases where it doesn't seem plausible, the methodology used to come to that conclusion as well. I've stated why, from a technical standpoint, the test you showed can't really affirm your claim. You can accept that or not.
You are the only one who actually don't agree with my methodology here, with your logic as broken and wrong as you think my methodology is.
Funny the way you always consider everything you say as THE absolute truth and clearly never consider you could ever be wrong. What makes you so sure you are right here?
In reality what you say is just your own opinion, just words on the internet, and has nothing else to show off, it has no more value than anybody else's opinion at that point.
But as you stated, the "proof is in the pudding". Obviously, the system has very good accuracy and quite possibly better than the original when dialed in, especially in the X direction where jitter is more of an issue with the original technology. Interestingly, that increase in accuracy is precisely what can mask a possible difference in speed when the positions are averaged, as they are in that calibration screen. Again, this is academic and related specifically to the claims you have made, and isn't intended to reflect poorly on the overall performance or quality of your system.
No, the CRT guncon at that distance does not exhibit more jittery than my gun, and no, averaging the aim won't make any significative difference on FAST motion. It's very basic math bud
A more accurate lightgun system will trump a one or two frame difference in reporting speed all day long, for what good is more data if a larger percentage of it is incorrect? Not much, and that doesn't seem to be the case with yours, so why so defensive?
Again, guncon and gun4ir are equally accurate in that setup, and no, it doesn't have any incidence on the speed of fast motions. For instance a jittery of 2~3 pixels (which is about what we get on the guns at that distance) is simply changing nothing when the gun moves at a speed of 20 pixel or more on each frame over the course of several frames. If one of the guns had a constant extra latency of one frame, in that theorical case it would always drag 20+ pixel behind what the other gun does, and be clearly visible in the video.
Averaging wouldn't hide that, as during the motion the lag would propagate to every single position.
When every single position data has the same offset, averaging them will NOT remove that offset, that's the opposite, it would actually show it more clearly and reliably without the jitter.
Again, very basic math. I can't believe I even have to explain that. Your point is totally irrelevent at best, very insulting at worse.
Showing that a controller is as fast as the host system and software will ever allow is mind-numbingly simple, provided you have a few cycles to spare. All it takes is adding a couple of lines of code to your firmware to toggle a spare pin, at the precise location where changes in your position calculations are "set in stone" and will be transferred, and then measuring the frequency of the signal on that pin with an oscilloscope. So long as you aren't working from buffered data, it will paint a very clear picture as to timeliness of the updates. If you are sending accurate updates 60 times a second and the host/software isn't able to act on those updates in near real-time, there's nothing you will ever be able to do about it. In other words, even if it's not as timely as the original hardware and methodology, it's not on you, and the increase in accuracy will probably make up for it "in spades".
Once again you have no clue how things work, and what I wanted to show.
Your suggestion is a very basic and widely used method to measure digital state change like with button, but won't work here because you are completely ignoring the latency of the sensor itself, so even if you measure the speed at which the sensor or the gun send data (which I did already, it's ~4ms for the sensor itself, ~5ms for the sensor+the rest, over several thousand samples) in comparison to the speed the host hardware handles it, it won't give you squat for the total latency.
Your methodology here is completely useless in this context, and doesn't show anything valuable I don't already know.
Even if I measure the latency of the sensor itself, it wouldn't show much valuable information for my end users, as it wouldn't be a real world case.
What I am showing here is how the gun can match the native guncon on the MiSTer fpga PS1 core, nothing more, nothing less.
It's not supposed to be a very technical video, just showing the MiSTer users what they can expect from it in real world use, which is what it is all about here.
When I said the gun4ir was doing as good as CRT guns at their own game few messages ago, you said you'd be curious to see a video that shows it.
Which is what I clearly did. Now that you accept it as proof or not it's totally on you. I know my methodology and the result of it are sound, especially after all the research and consulting I did, no matter what you think you might know better.
Some of us just don't make claims without actually thoroughly studying and testing that claim by themselves
And I accept any criticism, but only when they actually make sense in the context.
But you clearly won't change your mind anyway, so let's agree to disagree and keep it that way, I wasted way too much time on this already.
