Author Topic: Hantarex MTC 9000 image squashed vertically  (Read 11037 times)
grantspain
Re: Hantarex MTC 9000 image squashed vertically
« Reply #40 on: September 07, 2019, 01:06:50 pm »
r94 is exactly the one, it should be a metal oxide 1w 3r9
its important to be a metal oxide as its a safety component so the one you linked to will be perfect
be77amyX
  • Last login:November 13, 2019, 01:24:01 am
« Reply #41 on: September 07, 2019, 06:51:46 pm »
Ordered. 10 of for 24p free next Day delivery. How do rs make money!? Lol
be77amyX
« Reply #42 on: September 10, 2019, 12:16:02 pm »
It Lives! newest update.. replaced R94 and powered up. Got a picture so reattached D10 and powered up and didn't go out on overvoltage protection so we're back to before I broke it!
B+ is now 132v but the image is still only half the screen height and rolled up at the bottom? see picture attached. any advice?
grantspain
« Reply #43 on: September 10, 2019, 01:29:14 pm »
still a fault in vertical circuit, could be broken track or bad ic
you may even have a bad yoke but that normally shows distortion as well
be77amyX
« Reply #44 on: September 11, 2019, 06:04:21 pm »
R43 has a broken leg! Tested out fine from underneath the board but on closer inspection the leg was hanging on by a thread. Soldered the leg back together and the picture is now perfect! Only issue now is there's a hissing/arcing noise coming from either the neck board or the ht cap and a high pitched squeal coming from the horizontal linearity coil which stops/changes when I put my finger on it!
grantspain
« Reply #45 on: September 12, 2019, 01:10:14 am »
if the hiss is neck card then i expect its the really old crt socket and they corrode internally, if its the anode then it could be slightly damp and will clear in some time or with a gentle clean, or there is corrosion on the connection of the anode clip to cable
lin coil you can manipulate the coil wire fractionally or reseal with a lacquer
be77amyX
« Reply #46 on: September 12, 2019, 09:59:22 am »
I'll check out the anode cap tonight. Is there anywhere that still sells the neck sockets? How would I go about resealing the coil? Also is there anywhere that sells replacements for them that your aware of?
grantspain
« Reply #47 on: September 12, 2019, 10:14:30 am »
quick fix for the coil is tape a wooden toothpick to it
what crt socket type is it?
be77amyX
« Reply #48 on: September 12, 2019, 05:24:27 pm »
Here's a picture of the CRT socket
grantspain
« Reply #49 on: September 13, 2019, 01:38:58 am »
rare to get issues on that type socket
