Author Topic: Sportcraft air hockey issue  (Read 4676 times)
MaseMan
  • Last login:March 14, 2024, 08:49:39 pm
« on: February 15, 2019, 06:41:25 pm »
Have an older Sportcraft air hockey table that works fine, other than the electronic scoring. Goals no longer register. I'm assuming it's a sensor issue, but not sure how to fix this. Any advice would be appreciated.
MaseMan
Re: Sportcraft air hockey issue
« Reply #1 on: February 22, 2019, 08:13:24 am »
Can anyone help with this? Here are some pics from underneath the table, to give a better idea of what I'm working with.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: February 22, 2019, 12:23:26 pm »
I've never seen of nor heard of that brand of air hockey table. Any pictures of the table and model/serial number nameplate?
  • Last login:Today at 07:32:32 pm
« Reply #3 on: February 22, 2019, 12:55:43 pm »
Looks like you're dealing with a microswitch sensor.
To test if the switch is the problem:
1. Remove power.
2. Scratch through the clear protective coating (if any) covering the microswitch PCB connection points (red arrows) to expose bare solder/metal.
3. Assuming this system uses a normally open switch, a multimeter should show no continuity between the points unless and until the switch is pressed.
4. Restore power.
5. When you short the points, the scoring electronics should register a goal.
- If it does, there is probably an electrical or mechanical problem with the microswitch/lever arm/linkage.
- If it doesn't, the problem is probably in the scoring electronics.
