Author Topic: Makvision/WeiYa Vertical collapsed bootom only  (Read 3393 times)
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« on: October 07, 2018, 03:41:21 pm »
Like my last post I am swamped and am reaching out to help me not spend a lot of time on these odd balls.
In the past week I have taken on about 20 more board repairs and I was already had a 10 board list.
So if any one has seen this and has some insight, here is the scoop.
Chassis says Wei Ya Probably Makvion M3129DS-LGC2929D1-LG
Originally vertical colllapse, replaced the Vert output IC now good picture on top. Bottom is black and a bright Horizontal Line in the center... Complete bottom vertical foldover.
Will scope the vertical circuit next.
Any thoughts greatly appreciated... I need to catch up!
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
grantspain
Re: Makvision/WeiYa Vertical collapsed bootom only
« Reply #1 on: October 07, 2018, 04:34:57 pm »
i have c67 marked down as oddball vertical fault in my repair notes, also the safety resistor and caps on the 24v supply- although you must have 24v or there would be no vertical
buttersoft
  • Last login:Today at 04:02:33 am
  • Is running at 15kHz
« Reply #2 on: October 07, 2018, 07:29:23 pm »
Got a schematic? Might help pick something preventing the vertical coil reversing polarity, i guess.
Rickn
« Reply #3 on: October 08, 2018, 12:41:32 pm »
Thanks Grant, if you have time please check your notes.. for the life of me I cannot find C67 either on the board or the schematic..
Odd as I can locate C68.
Yes I have what appears to be the right schematic.
May have to set it aside for now.
Ric
Rick Nieman
519-621-1722
grantspain
« Reply #4 on: October 08, 2018, 04:25:08 pm »
220nf 100v  on r107
thats if it a m3129 chassis, no idea on a m2929 chassis
Rickn
« Reply #5 on: October 08, 2018, 07:34:53 pm »
Thanks Grant, the 2 boards are use different vertical IC's. I expect the cap in yours is a small tantalum cap off of pin 1 of the TDA 1675. The board I have by memory is TDA 1672..yes these puppies can cause weird issues, not usually the bottom vertical foldover. tHE 2929d1 Uses a TDA 8172.
Thanks I will plug on!
Rick Nieman
519-621-1722
