Author Topic: Wells Gardner K7000 Arcade Monitor  (Read 1620 times)
tfity
  • Last login:April 02, 2019, 11:05:13 am
« on: September 29, 2018, 08:37:55 am »
Hello,
I have a Wells Gardner K7000 arcade monitor. However, I do not have the transformer for it. But I am going to try to pick up one today from an arcade auction (possibly just going to pick up a whole new harness). My questions is, do I need a separate power supply for the monitor, if I have the transformer? As of now, I am running from a raspberri pi setup that I would plug directly to the wall.
-Tom
Ken Layton
  • Guru
  • Technician
Re: Wells Gardner K7000 Arcade Monitor
« Reply #1 on: October 01, 2018, 01:08:36 am »
The isolation transformer is for powering the monitor only.
tfity
« Reply #2 on: October 03, 2018, 07:39:48 pm »
I understand. But can I plug it directly into the wall if I have the transformer hooked up?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: October 03, 2018, 10:16:01 pm »
You plug the isolation transformer into the wall outlet. Then the output of the isolation transformer gets connected to the monitor.
keilmillerjr
  • Web Developer.
« Reply #4 on: October 08, 2018, 08:32:20 pm »
Isolation transformer is 120VAC. It should be the same as a household wall outlet in USA. On a generic arcade power supply, you might see it tied to the 120VAC+ and 120VAC-. PC style arcade power supplies will have it looped from the wall to one of the harnesses.
Ps I have the same monitor. If you have v-hold issues, you might need a new remote board. Paradise Arcade sells a PA made replacement.
