Author Topic: [Solved] Help to run vertical games on horizontal screen  (Read 2541 times)
processor
  • Last login:June 18, 2018, 04:04:27 am
« on: May 27, 2018, 02:14:48 pm »
Hi,
I have setup a mamecab with GAL 2108 DVD. I use my config on a nanao MS9-29.
Everything works without any problem except vertical games like 19xx or Mercs. (on my horizontal config)
The  games run, but on the screen they seem to be out of sync.
I tried with rotate or norotate switch and it did not helped.
Many  thanks by advance to anyone that could lead me to the solution.
Proc.
« Last Edit: May 28, 2018, 04:23:41 pm by processor »
--Processor
buttersoft
  • Last login:April 21, 2024, 08:06:32 am
  • Is running at 15kHz
Re: Help to run vertical games on horizontal screen
« Reply #1 on: May 27, 2018, 07:24:51 pm »
This is not very clear. What is GAL 2018 DVD?
Where did you set the rotation, in VMM or in mame.ini? You could try changing the "orientation" variable in mame.ini to "horizontal". That locks the screen, so switchres knows it has to display vertical games within a horizontal mode.
If this is all stuff you've tried already, post a log instead :)
processor
« Reply #2 on: May 28, 2018, 05:05:22 am »
Hi,
Sorry if was not clear enough:
GAL DVD is for Groovy Arcade Linux DVD : http://forum.arcadecontrols.com/index.php/topic,130667.0.html
I setup my screen orientation here :
I'll give a try to modify it directly in mame.
--Processor
processor
« Reply #3 on: May 28, 2018, 03:13:00 pm »
Hi,
Screen orientation is already set on horizontal in mame.ini.
here is my mame.ini:
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
homepath                  .
rompath                   /home/roms/BIOS_roms;/home/roms/MAME/roms;
hashpath                  $HOME/hash
samplepath                /home/roms/MAME/samples
artpath                   /home/roms/MAME/artwork
ctrlrpath                 /home/roms/MAME/ctrlr
inipath                   $HOME/.mame;$HOME;.;$HOME/ini
fontpath                  /home/roms/MAME/fonts
cheatpath                 /home/roms/MAME/cheat
crosshairpath             /home/roms/MAME/crosshair
pluginspath               /home/roms/MAME/plugins
languagepath              /home/roms/MAME/language
swpath                    /home/roms/MAME/software
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             $HOME/cfg
nvram_directory           $HOME/nvram
input_directory           $HOME/inp
state_directory           $HOME/sta
snapshot_directory        /home/roms/MAME/snaps
diff_directory            $HOME/diff
comment_directory         $HOME/comments
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
record_timecode           0
exit_after_playback       0
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
autosync                  1
sleep                     1
speed                     1.0
refreshspeed              0
# CORE RENDER OPTIONS
keepaspect                1
unevenstretch             1
unevenstretchx            0
unevenstretchy            0
autostretchxy             0
intoverscan               0
intscalex                 0
intscaley                 0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
beam_width_min            1.0
beam_width_max            1.0
beam_intensity_weight     0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  1
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          1
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           lightgun
positional_device         keyboard
mouse_device              lightgun
# CORE DEBUGGING OPTIONS
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
# CORE COMM OPTIONS
comm_localhost            0.0.0.0
comm_localport            15112
comm_remotehost           127.0.0.1
comm_remoteport           15112
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             1
uifont                    default
ui                        cabinet
ramsize
confirm_quit              0
ui_mouse                  1
autoboot_command
autoboot_delay            0
autoboot_script
console                   0
plugins                   1
plugin
noplugin
language                  English
# HTTP SERVER OPTIONS
http                      0
http_port                 8080
http_root                 web
# CORE SWITCHRES OPTIONS
modeline_generation       1
monitor   ms929
orientation   horizontal
connector                 auto
interlace                 1
doublescan                1
super_width               2560
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
vsync_offset              0
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# OSD KEYBOARD MAPPING OPTIONS
uimodekey                 SCRLOCK
# OSD FONT OPTIONS
uifontprovider            auto
# OSD OUTPUT OPTIONS
output                    auto
# OSD INPUT OPTIONS
keyboardprovider          auto
mouseprovider             auto
lightgunprovider          auto
joystickprovider          auto
# OSD DEBUGGING OPTIONS
debugger                  auto
debugger_font             auto
debugger_font_size        0
watchdog                  0
# OSD PERFORMANCE OPTIONS
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     opengl
numscreens                1
window                    0
maximize                  1
waitvsync                 0
monitorprovider           auto
# OSD PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect    4:3
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 1
# OSD ACCELERATED VIDEO OPTIONS
filter                    0
prescale                  1
# OpenGL-SPECIFIC OPTIONS
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl   0
gl_glsl_filter            1
glsl_shader_mame0         /home/arcade/CRT/shader/glsl_plain
glsl_shader_mame1         /home/arcade/CRT/CRT-geom
glsl_shader_mame2         none
glsl_shader_mame3         none
glsl_shader_mame4         none
glsl_shader_mame5         none
glsl_shader_mame6         none
glsl_shader_mame7         none
glsl_shader_mame8         none
glsl_shader_mame9         none
glsl_shader_screen0       none
glsl_shader_screen1       none
glsl_shader_screen2       none
glsl_shader_screen3       none
glsl_shader_screen4       none
glsl_shader_screen5       none
glsl_shader_screen6       none
glsl_shader_screen7       none
glsl_shader_screen8       none
glsl_shader_screen9       none
# OSD SOUND OPTIONS
sound                     auto
audio_latency             2.0
# PORTAUDIO OPTIONS
pa_api                    none
pa_device                 none
pa_latency                0
# BGFX POST-PROCESSING OPTIONS
bgfx_path                 bgfx
bgfx_backend              auto
bgfx_debug                0
bgfx_screen_chains        default
bgfx_avi_name             auto
# SDL PERFORMANCE OPTIONS
sdlvideofps               0
# SDL VIDEO OPTIONS
centerh                   1
centerv                   1
scalemode                 none
# SDL FULL SCREEN OPTIONS
useallheads               0
# SDL KEYBOARD MAPPING
keymap                    0
keymap_file               keymap.dat
# SDL JOYSTICK MAPPING
joy_idx1                  auto
joy_idx2                  auto
joy_idx3                  auto
joy_idx4                  auto
joy_idx5                  auto
joy_idx6                  auto
joy_idx7                  auto
joy_idx8                  auto
sixaxis                   0
# SDL LIGHTGUN MAPPING
lightgun_index1           WiiMote0
lightgun_index2           WiiMote1
lightgun_index3           auto
lightgun_index4           auto
lightgun_index5           auto
lightgun_index6           auto
lightgun_index7           auto
lightgun_index8           auto
# SDL MOUSE MAPPING
mouse_index1              auto
mouse_index2              auto
mouse_index3              auto
mouse_index4              auto
mouse_index5              auto
mouse_index6              auto
mouse_index7              auto
mouse_index8              auto
keyb_idx1                 auto
keyb_idx2                 auto
keyb_idx3                 auto
keyb_idx4                 auto
keyb_idx5                 auto
keyb_idx6                 auto
keyb_idx7                 auto
keyb_idx8                 auto
# SDL LOWLEVEL DRIVER OPTIONS
videodriver               auto
renderdriver              auto
audiodriver               auto
gl_lib                    auto
Exemple of game output :
Code: [Select]
SwitchRes: [19xx] (1) vertical (224x384@59.637405)->(400x384@58.588234)
Many thx by advance for any help.
--Processor
Calamity
  • Moderator
  • Last login:April 10, 2024, 02:02:31 pm
  • Quote me with care
« Reply #4 on: May 28, 2018, 03:57:51 pm »
Your MS9-29 is probably the non-autoswitching version. Use the arcade_15 preset instead.
Steps to create a log:
processor
Re: [Solved] Help to run vertical games on horizontal screen
« Reply #5 on: May 28, 2018, 04:25:52 pm »
You're the man!
Many thanks it works. Could my MS9 be an autoswitch release but with the ability disbaled? Do you know how to identify one from another?
Thanks again.
Proc.
--Processor
Sledge
  • Last login:September 25, 2022, 05:22:55 am
« Reply #6 on: May 29, 2018, 04:30:14 am »
https://forum.arcadeotaku.com/viewtopic.php?t=21831
