Author Topic: Help replacing LED in Joystick  (Read 1406 times)
mhermann
  • Last login:October 04, 2019, 07:10:08 pm
  • We ain't found.........
« on: May 23, 2018, 02:20:50 pm »
Hello all. Been a while since I have been back here. Need a little guidance. After building my first Arcade machine 10 years ago, I bought a pre-made 4 player panel from East Coast Customs like 6 years ago. Recently 2 of the joysticks no longer light up. It looks like the cables got twisted and probably caused them to break. They are attached to an LED Wiz.
I am having a hard time finding what part I need to get to replace.
I probably should post a few picks but am at work right now. I will post the pics when I get home.
If anyone can point me in the right direction that would be very helpful.
Titchgamer
Re: Help replacing LED in Joystick
« Reply #1 on: May 23, 2018, 03:50:42 pm »
If the wires broken just cut out the broken part and splice it back together?
  • Last login:Today at 12:45:44 am
« Reply #2 on: May 23, 2018, 06:10:45 pm »
GGG and Paradise have slip-ring connections that will keep the joystick handle LED wires from getting twisted/broken.
GGG - https://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=70&products_id=382
Paradise Arcade Shop - https://paradisearcadeshop.com/home/controls/accessories/376_ultimate-arcade-slip-ring
mhermann
« Reply #3 on: May 24, 2018, 04:12:19 pm »
I will definitley pick up a couple slip rings.
I don't think the wire actually broke,  Although that may be the case they are still inside the installation. I think the LED is actually out. I found the replacement on Paradise Arcade.
One question though. I read this in the description and not sure what else I need to hook it up to my LED Wiz. I don't see anything else connected from the LED to the board currently.
"Please note these do not have resistors installed so they will need a current control circuit (or resistor) to run properly."
« Reply #4 on: May 24, 2018, 08:40:23 pm »
The resistor for the old LED was probably concealed under heat-shrink.
Please post a link to the replacement LED so we can help you find the correct current limiting resistor and figure out how to wire the whole circuit.
