Author Topic: [Solved][GroovyArcade] How to edit video port after graphic card swap?  (Read 2112 times)
Cucurbitacée
  • Last login:October 04, 2021, 02:26:59 pm
Hi,
I couldn't find any answer for this specific topic, so I'll ask directly. In my quest to fix my supersonic fast 2018 install (http://forum.arcadecontrols.com/index.php/topic,130667.msg1649528.html#msg1649528) I used another graphic card. But as the new one is working on VGA-0 instead of DVI-1 and I don't  get any picture.
I edited /etc/X11/xorg.conf and changed the value, but it doesn't work. Which I guess makes sense, X11 is not running a start. Anyway, can someone tell me how I can change the active port?
« Last Edit: April 14, 2018, 01:35:39 pm by Cucurbitacée »
Cucurbitacée
Re: [GroovyArcade] How to edit video port after graphic card swap?
« Reply #1 on: April 14, 2018, 01:34:59 pm »
Hi,
I reply to myself as I found the answer after a long grep on the whole drive. I'll put the answer here in case someone else stumble on this in the future. You need to edit
Code: [Select]
/boot/syslinux/syslinux.cfgI don't know why but I couldn't see this file (or the content of the whole /boot folder for that matter) with the LiveCD, I had to swap the monitor with an LCD one.
Anyway, case closed for this one. ;D
ves
  • Last login:April 11, 2020, 02:57:49 am
Hi
For xorg you need select again a monitro from menú vídeo monitor.
For boot in the menú vídeo boot options
Calamity
  • Moderator
  • Last login:April 10, 2024, 02:02:31 pm
  • Quote me with care
Basically, redo your video configuration from gasetup.
Steps to create a log:
