Author Topic: Plastic/aluminum control panels for Sanwa buttons  (Read 2064 times)
gutterstuff
  • Last login:February 01, 2021, 01:08:53 pm
« on: February 17, 2018, 11:59:25 am »
Hey everyone,
Because there's a market for pretty much everything these days, I figured that a guy building a cabinet with clip-in Sanwa parts might be able to find pre-fabricated 1/8 inch panels somewhere online. With the popularity of Hori sticks, swap-able buttons and Pi arcade building, I thought it would be best to ask folks here if they've seen anything in the wild.
I'm not particular about the layout (joystick, 8 button perhaps?) but I am sick of seeking out hard to find 1/8 sheets of aluminum when there's probably a fast and easy Ebay solution out there.
Thanks everyone,
nitrogen_widget
  • Last login:March 30, 2024, 09:10:09 am
« Last Edit: February 17, 2018, 09:08:39 pm by nitrogen_widget »
gutterstuff
Re: Plastic/aluminum control panels for Sanwa buttons
« Reply #2 on: February 20, 2018, 11:07:56 am »
Oh wow -- I would have just assumed that to ship aluminum sheets it would be far more expensive. Thanks so much -- do you have a picture of how you used either on your cab?
Cheers!
JDFan
  • Last login:May 21, 2023, 04:07:42 pm
« Reply #3 on: February 20, 2018, 12:15:59 pm »
In addition to the ones nitrogen_widget posted they also have Blank panels that do not have any button holes drilled so you can make your own layout for $23 + $12 SHipping-- https://www.ebay.com/itm/MIDWAY-UR-CONTROL-PANEL-BLANK-MULTICADE-DRILL-YOUR-OWN-HOLES/380599924854?hash=item589d85f876:g:xjAAAOSwGIRXZz4N
paigeoliver
  • Awesome face!
« Reply #4 on: February 20, 2018, 03:51:09 pm »
Arcade panels generally are not aluminum, they are steel or wood. Sometimes they have an aluminum overlay though.
shaolindrunkard
  • Last login:August 19, 2021, 11:13:43 am
« Reply #5 on: February 20, 2018, 06:32:37 pm »
This is very true, aluminum is a soft metal and even 1/8 can bend with a bit of pressure.
When I used to do custom arcade sticks I would make the top panel out of wood and put an overlay of 1/8 plexiglass on top of that, the plexi glass would hold the Sanwas in fine and the wood would support them...
gutterstuff
« Reply #6 on: February 21, 2018, 12:31:00 pm »
This is very much my approach, but in the case of my current cab, it has 3/4 risers in the centre that won't accommodate plexi -- that, and I'm going for a sexeh matte finish this time around.
Thanks everyone.
