Author Topic: GroovyMAME Audio Skipping, not a Problem in MAMEUIFX or MAMEDev Versions  (Read 4319 times)
P.H.U.
I have a Dell Optiplex 390 that I am using for a cab build. With the embedded sound card, I am getting skipped audio beats even though the DOS console shows that the game is running at 100% speed. Thinking it is the default Windows 7 WDDM drivers causing the problem, I updated the drivers to the correct Conexant audio drivers from Dell. Still the same problem. Today, I disabled the embedded audio and installed a PCIe sound card. I was shocked to see that the problem followed with the new sound card!! I started playing around with the audio_latency switch. I noticed some improvement but no fix.
I decided to give MAMEUIFX a try and there was no audio skipping! I tried the same with MAMEDev's official build, no problems there either. Now I have MAME set 0.170 and 0.166. But I don't see a problem being due to the MAME set as I have used this same set for cab builds for a few years now. There is definitely something about the Dell Optiplex 390 that GroovyMAME does no like that is not related to the sound card. Any ideas what could be going wrong or what switches I need to turn on to resolve this?
Processor:  i3-2120 @3.30GHz
RAM:  8GB
Video:  Radeon HD4650 (still running default MS WDDM drivers)
Audio:  C-Media PCI Audio
Calamity
  • Moderator
  • Last login:April 10, 2024, 02:02:31 pm
  • Quote me with care
Re: GroovyMAME Audio Skipping, not a Problem in MAMEUIFX or MAMEDev Versions
« Reply #1 on: January 30, 2018, 04:05:46 pm »
Which version? Which game/games? Any chance to see a log?
Steps to create a log:
P.H.U.
« Reply #2 on: January 30, 2018, 04:11:19 pm »
This happens with GroovyMAME 0.166 with the 0.166 MAME set. This happens with GroovyMAME 0.170 with the 0.170 MAME set. This happens with the GroovyMAME 0.193 with either 0.166 and 0.170 sets. Happens with sf2, sfiii3 as these are my go to games to test if my setup is working.
How do I retrieve a log?
Log for for GroovyMAME 0.170 for sf2:
EDIT:  See below post.
« Last Edit: January 30, 2018, 05:21:38 pm by P.H.U. »
P.H.U.
« Reply #3 on: January 30, 2018, 04:48:50 pm »
DELETED.
« Last Edit: January 30, 2018, 05:22:04 pm by P.H.U. »
Calamity
  • Moderator
« Reply #4 on: January 30, 2018, 05:02:16 pm »
Those are not logs my friend.
Calamity
  • Moderator
« Reply #5 on: January 30, 2018, 05:14:51 pm »
Check my signature.
In the meantime, try:
groovymame.exe game -nosyncrefresh -nowaitvsync -notriplebuffer
P.H.U.
« Reply #6 on: January 30, 2018, 05:16:11 pm »
Log for for GroovyMAME 0.170 for sf2, sfiii3, dkong:
« Last Edit: January 30, 2018, 05:23:19 pm by P.H.U. »
P.H.U.
« Reply #7 on: January 30, 2018, 05:21:04 pm »
Check my signature.
Whoops. I guess I asked he dumbest question ever. Missed your sig :).
Gave this a whirl. No difference if possibly, it made it worse. Here is the log:
Calamity
  • Moderator
« Reply #8 on: January 30, 2018, 05:28:56 pm »
There are certainly lots of sound overflows in there, don't know why.
I'm sorry to sound like a jerk asking logs and stuff, but what I need are the logs for 193, the only version that has a chance to get fixed. Whatever happened with 170, is in the past.
P.H.U.
« Reply #9 on: January 30, 2018, 05:37:06 pm »
Don't apologize Boss. I appreciate your help and all you do for this project. Logs attached!
Calamity
  • Moderator
« Reply #10 on: January 30, 2018, 05:56:23 pm »
Thanks.
Some things to try:
- groovymame game -syncrefresh
- groovymame game -sound xaudio2
- groovymame game -sound portaudio -pa_api "Windows WASAPI" -pa_latency 0.003334 -audio_latency 1
P.H.U.
« Reply #11 on: January 30, 2018, 06:02:15 pm »
Thanks.
Some things to try:
These all exacerbate the problem unfortunately.
Calamity
  • Moderator
« Reply #12 on: January 30, 2018, 06:11:39 pm »
My last idea:
groovymame game -monitor lcd
P.H.U.
« Reply #13 on: January 30, 2018, 08:10:36 pm »
My last idea:
Same. Exacerbates the problem.
krick
  • Last login:February 08, 2023, 08:30:27 pm
  • Gotta have blue hair.
« Reply #14 on: January 30, 2018, 10:57:20 pm »
When you try different versions, are you running them each in a separate directory?
INI and config files are not compatible across versions so unzipping it into an existing folder is bad.
Are you running aggressive anti-virus software?
Are there any background processes running?
This shouldn't be happening in this day and age, but maybe there's an interrupt conflict with another device on the PCI bus?
If your video card has an HDMI port, see if there's an HDMI audio driver installed for it.  I had that with a Radeon HD 4550 and it caused conflicts.  I had to uninstall the HDMI audio driver and I think I disabled the device in device manager to stop Windows from automatically installing a new driver.  It's been a while so I can't remember exactly.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
P.H.U.
« Reply #15 on: January 30, 2018, 11:55:03 pm »
All the different versions of MAME are in there own directory and have their own *.ini files in their own directories. But the roms folders are pointing to a single location on the GroovyMAME folder. That shouldn't be a problem.
This happens on a clean install of Windows with Microsft Security Essentials installed or not. The intent is this goes into a cab so I don't care too much about making it secure. I only install the convenience roll-up pack, DX, VC++, .Net, and a codec pack.
Let me disable some ports in the CMOS and see if that remedies things. Certainly don't need the serial port or whatever might be enabled. Perhaps I can disable the front panel audio while I am in there. Going to remove that PCIe sound card I picked up. It didn't help the problem at all. Also, keep in mind MAMEUIFX and MAMEDEV's version works fine! But I'll give it a shot.
Let me give this a try. FYI, this happens only on this machine. I have built a half dozen or so boxes for this purpose and seems this is the only machine that has the problem. I have tried other HD4000 series cards, same problem. But yeah, will give this a shot.
Will be traveling for the next few days, but will report back then. Until then, let the ideas flow. Much appreciated.
P.H.U.
« Reply #16 on: February 01, 2018, 01:24:02 am »
Before I left for work, I gave this a whirl. Just didn't get a chance to post the results last night.
According to the Device Manager, there is no conflict. In the CMOS, the "Serial" port is disabled on the mainboard, even though I don't see a serial connector on the back I/O panel. As far as I know, no IRQ conflicts. Again, the problem doesn't happen in MAMEUIFX or MAMEDev's versions. I will admit, this main board is funky at times. The HDD does not initialize on boot-up from time to time and I have to do a hard reset even though I am using UEFI, same thing even happens in Legacy Boot mode. But that doesn't explain why it would work in the other forks of MAME. I have also updated the BIOS to the latest version, reverted to the older version and back and forth, no change. I disabled the High Definition Audio Device in the Device Manager (HDMI audio), then uninstalled the driver. Still have the same problem. I am thinking this motherboard just happens to be cursed somehow.
Calamity, if this seems too isolated, then I would rather save your cycles for other things. I can go with MAMEUIFX or MAMEDev for this particular build since they work. Let me know if that is the best way forward.
kai
  • Last login:November 08, 2018, 06:41:51 pm
I just got my Dell Optiplex 390 SFF 3 days ago and I spent 2 days to struggle with it against the sound skipping issue on Groovymame.
I got exactly the same issue as P.H.U got.
I used the latest 0.197 version and tried lots of combinations, but no luck.
Now I am inclined to believe Optiplex 390 is cursed, please stay away from it!! :badmood:
(I really do not want to switch to official mame since i like the Groovymame's "nearly 0 lag input")
