Author Topic: Joytokey issues with Rocketlauncher/Hyperspin  (Read 3147 times)
JudgeRob
  • Last login:July 13, 2024, 10:00:33 pm
« on: November 13, 2017, 04:44:52 pm »
Hi there,
Strange issue with joytokey.  When I enable it in Rocketlauncher, I get the following issue.  When starting a game in Hyperspin, the game will launch but it launches in the background.  The screen flashes but goes back to Hyperspin screen while MAME runs in a separate background window.
I've set joytokey to open and run in minimized mode, so it does not open its own window.  And if I disable joytokey in Rocketlauncher, everything seems to work fine.
Any ideas about why joytokey is causing this behavior?
JudgeRob
Re: Joytokey issues with Rocketlauncher/Hyperspin
« Reply #1 on: November 14, 2017, 12:12:28 am »
Finally came across this:
http://hyperspin-fe.com/forums/topic/14026-focus-issue-when-using-joytokey/
I have no idea why, but setting the logging level to "troubleshooting" fixes the problem.  I can't imagine what the connection is.  I just hope it isn't an issue leaving it at this setting forever... ?
JudgeRob
« Reply #2 on: December 12, 2017, 06:47:47 pm »
FYI, in case anyone else has this problem, there is a better fix.  Enable fade in Rocketlauncher.  I had fade disabled and had the problems with the focus, etc. when joytokey was enabled.  For some reason enabling fade allows joytokey to work fine.
