Author Topic: Can I swap this out???  (Read 2233 times)
dunginhawk
  • Last login:August 24, 2017, 11:10:36 pm
« on: August 22, 2017, 11:12:51 pm »
Good evening.. first post, just a quick question... (im reading a lot, great forum you have here).
I am wondering if there is any way to swap out https://www.amazon.com/ZYOU-Buttons-Joystick-Controller-Fighting/dp/B0719GFTQS/ref=sr_1_11?s=toys-and-games&ie=UTF8&qid=1503455032&sr=1-11&keywords=happ+joystick+kit
That joystick, with a stick like the old fighter games like this.
https://www.amazon.com/EG-Starts-Competition-Standard-Joystick/dp/B01MY8TF7L/ref=sr_1_7?s=toys-and-games&ie=UTF8&qid=1503455032&sr=1-7&keywords=happ+joystick+kit
I just cant seem to find if threads are matched etc... so if anyone has any experience with that, that would be great.
I dont mean the entire thing, clearly thats possible, but just the stick itself.
thanks
« Last Edit: August 22, 2017, 11:33:03 pm by dunginhawk »
eds1275
  • Last login:November 05, 2025, 09:52:44 am
  • Rock and Roll!
Re: Can I swap this out???
« Reply #1 on: August 23, 2017, 02:11:56 pm »
Might have to do a little tinkering but it shouldn't be too difficult.
« Reply #2 on: August 23, 2017, 03:42:13 pm »
It won't fit.  The holes do not line up.  The one you have is a Japanese layout.  The HAPP layout is different.
You'd have to drill new holes for the new joystick.  Hence the modding.
DeL
« Reply #3 on: August 23, 2017, 03:56:25 pm »
thanks
No, but they do make bat tops for the Japanese style sticks.
(they are a bit smaller than the one on the happ style joysticks though)
https://www.focusattack.com/sanwa-lb-30-n-s-battop-black/
EDIT: add a joystick shaft cover and a stiffer spring to make it more like the American style sticks
« Last Edit: August 23, 2017, 03:58:53 pm by BadMouth »
« Reply #4 on: August 23, 2017, 05:35:19 pm »
Alternatively, you can get an American stick and this adapter plate the will allowing swapping of brands, without having to drill new holes.
https://paradisearcadeshop.com/paradise-universal-plates/1175-universal-arcade-joystick-adapter-plate.html
DeL
dunginhawk
« Reply #5 on: August 23, 2017, 10:54:27 pm »
thanks
this is what i was looking for... I dont have good access under the board though, so adding a spring may be tough.. but at least I can add the top stick part.
thank you
keilmillerjr
  • Web Developer.
« Reply #6 on: August 24, 2017, 08:06:00 am »
DeL
That Adapter worked to allow my jlf fit in my neo geo mvs. It's a good product.
dunginhawk
« Reply #7 on: August 24, 2017, 10:16:08 pm »
the joystick is mounted underneath, and I dont have access to the screws etc to swap a plate etc.  The only thing i can really do is change the ball to something else :)
