Author Topic: Anyone use LCD and Nvidia gfx card? Are you encountered this?  (Read 2252 times)
inv
  • Last login:August 10, 2020, 10:35:44 pm
I use a NVIDIA GeForce GTX 960 card and get a flicker tearing on the most top of screen,  can't get rid of it.
My settings are WIN10, GM 0.186, d3d9ex, frame_delay 3, 1080p full screen LCD, no HLSL.
Set vsync_offset from 0 to 200 or 100 can't help.
But my another PC, use similar settings, frame_delay 3, vsync_offset 20, with an AMD 7850 card, get no flicker tearing. :dunno
inv
Re: Anyone use LCD and Nvidia gfx card? Are you encountered this?
« Reply #1 on: June 30, 2017, 07:49:33 pm »
Here's my log with Nvidia GTX960.
Code: [Select]
SwitchRes: v0.017d, Monitor: lcd, Orientation: horizontal, Modeline generation: enabled
SwitchRes: Using default vfreq range for LCD 59.000000-61.000000
SwitchRes: \\.\DISPLAY1: NVIDIA GeForce GTX 960 (PCI\VEN_10DE&DEV_1401&SUBSYS_32021462&REV_A1)
SwitchRes: Device key: System\CurrentControlSet\Control\Video\{9BB76281-2772-4D68-ABBF-0DC4E8409F87}\0000
Video chipset is not compatible.
Switchres: Searching for custom video modes...
Switchres: [  1]  640x 480 @ 60 : system mode
Switchres: [  2]  640x 480 @ 75 : system mode
Switchres: [  3]  720x 480 @ 60 : system mode
Switchres: [  4]  720x 480 @ 75 : system mode
Switchres: [  5]  720x 576 @ 60 : system mode
Switchres: [  6]  720x 576 @ 75 : system mode
Switchres: [  7]  800x 600 @ 60 : system mode
Switchres: [  8]  800x 600 @ 75 : system mode
Switchres: [  9] 1024x 768 @ 60 : system mode
Switchres: [ 10] 1024x 768 @ 75 : system mode
Switchres: [ 11] 1152x 864 @ 60 : system mode
Switchres: [ 12] 1152x 864 @ 75 : system mode
Switchres: [ 13] 1280x 720 @ 60 : system mode
Switchres: [ 14] 1280x 768 @ 60 : system mode
Switchres: [ 15] 1280x 800 @ 60 : system mode
Switchres: [ 16] 1280x 960 @ 60 : system mode
Switchres: [ 17] 1280x 960 @ 75 : system mode
Switchres: [ 18] 1280x1024 @ 60 : system mode
Switchres: [ 19] 1280x1024 @ 75 : system mode
Switchres: [ 20] 1360x 768 @ 60 : system mode
Switchres: [ 21] 1366x 768 @ 60 : system mode
Switchres: [ 22] 1600x 900 @ 60 : system mode
Switchres: [ 23] 1600x1024 @ 59 : system mode
Switchres: [ 24] 1600x1024 @ 60 : system mode
Switchres: [ 25] 1680x1050 @ 59 : system mode
Switchres: [ 26] 1680x1050 @ 60 : system mode
Switchres: [ 27] 1920x1080 @ 60* : system mode
SwitchRes: Found 0 custom of 27 active video modes
SwitchRes: Creating automatic specs for LCD based on VESA GTF
SwitchRes: Monitor range 65962.00-68198.00,59.00-61.00,0.741,1.157,1.898,0.015,0.045,0.507,0,1,1080,1080,0,0
SwitchRes: -resolution was forced as 1920x1080@60
SwitchRes: Entering switchres_modeline_setup
SwitchRes: v0.017d:[captcomm] Calculating best video mode for 384x224@59.637405 orientation: normal
SwitchRes: [ 640]x[ 480]_[60=60.000000Hz] - locked
SwitchRes: [ 640]x[ 480]_[75=75.000000Hz] - locked
SwitchRes: [ 720]x[ 480]_[60=60.000000Hz] - locked
SwitchRes: [ 720]x[ 480]_[75=75.000000Hz] - locked
SwitchRes: [ 720]x[ 576]_[60=60.000000Hz] - locked
SwitchRes: [ 720]x[ 576]_[75=75.000000Hz] - locked
SwitchRes: [ 800]x[ 600]_[60=60.000000Hz] - locked
SwitchRes: [ 800]x[ 600]_[75=75.000000Hz] - locked
SwitchRes: [1024]x[ 768]_[60=60.000000Hz] - locked
SwitchRes: [1024]x[ 768]_[75=75.000000Hz] - locked
SwitchRes: [1152]x[ 864]_[60=60.000000Hz] - locked
SwitchRes: [1152]x[ 864]_[75=75.000000Hz] - locked
SwitchRes: [1280]x[ 720]_[60=60.000000Hz] - locked
SwitchRes: [1280]x[ 768]_[60=60.000000Hz] - locked
SwitchRes: [1280]x[ 800]_[60=60.000000Hz] - locked
SwitchRes: [1280]x[ 960]_[60=60.000000Hz] - locked
SwitchRes: [1280]x[ 960]_[75=75.000000Hz] - locked
SwitchRes: [1280]x[1024]_[60=60.000000Hz] - locked
SwitchRes: [1280]x[1024]_[75=75.000000Hz] - locked
SwitchRes: [1360]x[ 768]_[60=60.000000Hz] - locked
SwitchRes: [1366]x[ 768]_[60=60.000000Hz] - locked
SwitchRes: [1600]x[ 900]_[60=60.000000Hz] - locked
SwitchRes: [1600]x[1024]_[59=59.000000Hz] - locked
SwitchRes: [1600]x[1024]_[60=60.000000Hz] - locked
SwitchRes: [1680]x[1050]_[59=59.000000Hz] - locked
SwitchRes: [1680]x[1050]_[60=60.000000Hz] - locked
SwitchRes: [1920]x[1080]_[60=60.000000Hz]
   rng(0): 1920 x1080_60.000000p 0.000000 [fract] scale(5, 4, 1) diff(0.00, 18.07, 0.3626) ratio(5.000, 4.821)
SwitchRes: [captcomm] (1) horizontal (384x224@59.637405)->(1920x1080@60.000000)
SwitchRes: Modeline "1920x1080_60 0.000000KHz 60.000000Hz" 0.000000 1920 0 0 0 1080 0 0 0   -hsync -vsync
SwitchRes: Setting option -rotate
SwitchRes: Setting option -noror
SwitchRes: Setting option -autoror
SwitchRes: Setting option -norol
SwitchRes: Setting option -noautorol
SwitchRes: Setting option -keepaspect
SwitchRes: Setting option -unevenstretch
SwitchRes: Setting option -nounevenstretchx
SwitchRes: Setting option -noblack_frame_insertion
SwitchRes: Setting option -syncrefresh
SwitchRes: Setting option -notriplebuffer
SwitchRes: Setting option -waitvsync
SwitchRes: Setting option -filter
Video: Monitor 65537 = "\\.\DISPLAY1" (primary)
Direct3D: Using Direct3D 9Ex
Physical width 1920, height 1080
Direct3D: Initialize
Direct3D: Configuring adapter #0 = NVIDIA GeForce GTX 960
Direct3D: Adapter has Vendor ID: 10DE and Device ID: 1401
Direct3D: Using dynamic textures
Direct3D: YUV format = RGB
Direct3D: Max texture size = 16384x16384
Direct3D: Device created at 1920x1080
Direct3D: First scanline: 0, Last scanline: 1079, Break scanline: 1049, Delay scanline: 216
Direct3D: Initialize HLSL
Direct3D: First store options
Direct3D: HLSL initialized
RawInput: APIs detected
PortAudio: API MME has 5 devices
PortAudio: MME: "Microsoft 声音映射器 - Input"
PortAudio: MME: "FrontMic (Realtek High Definiti"
PortAudio: MME: "Microsoft 声音映射器 - Output"
PortAudio: MME: "扬声器 (Realtek High Definition" (default)
PortAudio: MME: "Realtek Digital Output (Realtek"
PortAudio: API Windows DirectSound has 5 devices
PortAudio: Windows DirectSound: "主声音捕获驱动程序"
PortAudio: Windows DirectSound: "FrontMic (Realtek High Definition Audio)"
PortAudio: Windows DirectSound: "主声音驱动程序" (default)
PortAudio: Windows DirectSound: "扬声器 (Realtek High Definition Audio)"
PortAudio: Windows DirectSound: "Realtek Digital Output (Realtek High Definition Audio)"
PortAudio: API Windows WASAPI has 3 devices
PortAudio: Windows WASAPI: "鎵0鍣?(Realtek High Definition Audio)" (default)
PortAudio: Windows WASAPI: "Realtek Digital Output (Realtek High Definition Audio)"
PortAudio: Windows WASAPI: "FrontMic (Realtek High Definition Audio)"
PortAudio: API Windows WDM-KS has 6 devices
PortAudio: Windows WDM-KS: "楹﹀厠椋?(Realtek HD Audio Mic input)"
PortAudio: Windows WDM-KS: "SPDIF Out (Realtek HDA SPDIF Out)"
PortAudio: Windows WDM-KS: "绔嬩綋澹版贩闊?(Realtek HD Audio Stereo input)"
PortAudio: Windows WDM-KS: "Speakers (Realtek HD Audio output)" (default)
PortAudio: Windows WDM-KS: "绾胯矾杈撳叆 (Realtek HD Audio Line input)"
PortAudio: Windows WDM-KS: "FrontMic (Realtek HD Audio Front Mic input)"
PortAudio: Using device "Speakers (Realtek HD Audio output)" on API "Windows WDM-KS"
PortAudio: Sample rate is 48000 Hz, device output latency is 2.00 ms
PortAudio: Allowed additional buffering latency is 10.00 ms/480 frames
Input: Adding keyboard #0: HID Keyboard Device (device id: \\?\HID#VID_046D&PID_C31C&MI_00#8&2583c8bd&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding mouse #0: HID-compliant mouse (device id: \\?\HID#VID_04CA&PID_0061#7&138429b&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding lightgun #0: HID-compliant mouse (device id: \\?\HID#VID_04CA&PID_0061#7&138429b&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Region ':maincpu' created
unzip: opened archive file D:\roms\mame roms\captcomm.zip
unzip: found D:\roms\mame roms\captcomm.zip ECD
unzip: D:\roms\mame roms\captcomm.zip has no ZIP64 ECD locator
unzip: read D:\roms\mame roms\captcomm.zip central directory
unzip: closing archive file D:\roms\mame roms\captcomm.zip and sending to cache
unzip: found D:\roms\mame roms\captcomm.zip in cache
Region ':gfx' created
Region ':audiocpu' created
Region ':oki' created
Region ':aboardplds' created
Region ':bboardplds' created
Region ':cboardplds' created
Starting Captain Commando (World 911202) ':'
Optional memory region ':stars' not found
Optional memory region ':key' not found
Optional shared pointer ':decrypted_opcodes' not found
Optional device ':msm2' not found
Optional device ':msm1' not found
Optional device ':m48t35' not found
Optional shared pointer ':output' not found
Optional shared pointer ':objram2' not found
Optional shared pointer ':objram1' not found
Optional shared pointer ':qsound_ram2' not found
Optional shared pointer ':qsound_ram1' not found
  (missing dependencies; rescheduling)
Starting M68000 ':maincpu'
Starting Z80 ':audiocpu'
Starting Video Screen ':screen'
Starting gfxdecode ':gfxdecode'
Starting palette ':palette'
Optional memory region ':palette:finder_dummy_tag' not found
Starting Speaker ':mono'
Starting Generic 8-bit latch ':soundlatch'
Starting Generic 8-bit latch ':soundlatch2'
Starting Yamaha YM2151 OPM ':2151'
Starting OKI MSM6295 ADPCM ':oki'
unzip: opened archive file cheat.zip
unzip: found cheat.zip ECD
unzip: cheat.zip has no ZIP64 ECD locator
unzip: read cheat.zip central directory
unzip: closing archive file cheat.zip and sending to cache
un7z: opened archive file newcheat.7z
un7z: closing archive file newcheat.7z and sending to cache
Loading cheats file from newcheat
un7z: opened archive file cheat_wayder.7z
un7z: closing archive file cheat_wayder.7z and sending to cache
unzip: found cheat.zip in cache
un7z: found newcheat.7z in cache
un7z: found cheat_wayder.7z in cache
renderer::end_frame(), probably missed retrace, entered at scanline 207, should break at 1049, realtime is 0.000000.
un7z: reopened archive file newcheat.7z
Sound: overflows=1 underflows=1
inv
« Reply #2 on: June 30, 2017, 07:53:30 pm »
And logs with AMD 7850 for compare.
Code: [Select]
SwitchRes: \\.\DISPLAY1: AMD Radeon HD 7800 Series (PCI\VEN_1002&DEV_6819&SUBSYS_27321462&REV_00)
SwitchRes: Device key: System\CurrentControlSet\Control\Video\{BA49BC3A-2736-4734-ADF0-AC013B468F72}\0000
ATI/AMD ADL init
ADL functions retrieved successfully.
Switchres: [  1]  640x 480 @ 59 : system mode
Switchres: [  2]  640x 480 @ 60 : ATI ADL timing "640x480_60 31.462000KHz 59.927620Hz" 25.170000 640 656 752 800 480 490 492 525   -hsync -vsync
Switchres: [  3]  640x 480 @ 75 : ATI ADL timing "640x480_75 37.500000KHz 75.000000Hz" 31.500000 640 656 720 840 480 481 484 500   -hsync -vsync
Switchres: [  4]  720x 480 @ 59 : system mode
Switchres: [  5]  720x 480 @ 60 : ATI ADL timing "720x480_60 31.468000KHz 59.939049Hz" 27.000000 720 736 798 858 480 489 495 525   -hsync -vsync
Switchres: [  6]  720x 576 @ 50 : ATI ADL timing "720x576_50 31.250000KHz 50.000000Hz" 27.000000 720 732 796 864 576 581 586 625   -hsync -vsync
Switchres: [  7]  720x 576 @ 59 : system mode
Switchres: [  8]  720x 576 @ 60 : system mode
Switchres: [  9]  800x 600 @ 60 : ATI ADL timing "800x600_60 37.878000KHz 60.315285Hz" 40.000000 800 840 968 1056 600 601 605 628   +hsync +vsync
Switchres: [ 10]  800x 600 @ 75 : ATI ADL timing "800x600_75 46.875000KHz 75.000000Hz" 49.500000 800 816 896 1056 600 601 604 625   +hsync +vsync
Switchres: [ 11] 1024x 768 @ 60 : ATI ADL timing "1024x768_60 48.363000KHz 60.003723Hz" 65.000000 1024 1048 1184 1344 768 771 777 806   -hsync -vsync
Switchres: [ 12] 1024x 768 @ 75 : ATI ADL timing "1024x768_75 60.022000KHz 75.027496Hz" 78.750000 1024 1040 1136 1312 768 769 772 800   +hsync +vsync
Switchres: [ 13] 1152x 648 @ 50 : ATI ADL timing "1152x648_50 37.500000KHz 50.000000Hz" 74.250000 1152 1656 1696 1980 648 689 694 750   +hsync +vsync
Switchres: [ 14] 1152x 648 @ 59 : system mode
Switchres: [ 15] 1152x 648 @ 60 : ATI ADL timing "1152x648_60 44.951000KHz 59.934666Hz" 74.170000 1152 1326 1366 1650 648 689 694 750   +hsync +vsync
Switchres: [ 16] 1280x 720 @ 50 : ATI ADL timing "1280x720_50 37.500000KHz 50.000000Hz" 74.250000 1280 1720 1760 1980 720 725 730 750   +hsync +vsync
Switchres: [ 17] 1280x 720 @ 59 : system mode
Switchres: [ 18] 1280x 720 @ 60 : ATI ADL timing "1280x720_60 44.951000KHz 59.934666Hz" 74.170000 1280 1390 1430 1650 720 725 730 750   +hsync +vsync
Switchres: [ 19] 1280x 768 @ 60 : system mode
Switchres: [ 20] 1280x 800 @ 60 : ATI ADL timing "1280x800_60 49.702000KHz 59.809868Hz" 83.500000 1280 1352 1480 1680 800 803 809 831   -hsync +vsync
Switchres: [ 21] 1280x 960 @ 60 : system mode
Switchres: [ 22] 1280x 960 @ 75 : system mode
Switchres: [ 23] 1280x1024 @ 60 : ATI ADL timing "1280x1024_60 63.981000KHz 60.019699Hz" 108.000000 1280 1328 1440 1688 1024 1025 1028 1066   +hsync +vsync
Switchres: [ 24] 1280x1024 @ 75 : ATI ADL timing "1280x1024_75 79.976000KHz 75.024391Hz" 135.000000 1280 1296 1440 1688 1024 1025 1028 1066   +hsync +vsync
Switchres: [ 25] 1600x 900 @ 60 : ATI ADL timing "1600x900_60 60.000000KHz 60.000000Hz" 108.000000 1600 1624 1704 1800 900 901 904 1000   +hsync +vsync
Switchres: [ 26] 1680x1050 @ 60 : ATI ADL timing "1680x1050_60 65.290000KHz 59.954086Hz" 146.250000 1680 1784 1960 2240 1050 1053 1059 1089   -hsync +vsync
Switchres: [ 27] 1776x1000 @ 25 : ATI ADL timing "1776x1000_25 56.250000KHz 50.000000Hz" 148.500000 1776 2376 2420 2640 1000 1044 1049 1125   +hsync +vsync
Switchres: [ 28] 1776x1000 @ 29 : system mode
Switchres: [ 29] 1776x1000 @ 30 : ATI ADL timing "1776x1000_30 67.431000KHz 59.938667Hz" 148.350000 1776 1936 1980 2200 1000 1044 1049 1125   +hsync +vsync
Switchres: [ 30] 1776x1000 @ 50 : ATI ADL timing "1776x1000_50 56.250000KHz 50.000000Hz" 148.500000 1776 2376 2420 2640 1000 1044 1049 1125   +hsync +vsync
Switchres: [ 31] 1776x1000 @ 59 : system mode
Switchres: [ 32] 1776x1000 @ 60 : ATI ADL timing "1776x1000_60 67.431000KHz 59.938667Hz" 148.350000 1776 1936 1980 2200 1000 1044 1049 1125   +hsync +vsync
Switchres: [ 33] 1920x1080 @ 25 : ATI ADL timing "1920x1080_25 56.250000KHz 50.000000Hz" 148.500000 1920 2448 2492 2640 1080 1084 1089 1125   +hsync +vsync
Switchres: [ 34] 1920x1080 @ 29 : system mode
Switchres: [ 35] 1920x1080 @ 30 : ATI ADL timing "1920x1080_30 67.431000KHz 59.938667Hz" 148.350000 1920 2008 2052 2200 1080 1084 1089 1125   -hsync -vsync
Switchres: [ 36] 1920x1080 @ 50 : ATI ADL timing "1920x1080_50 56.250000KHz 50.000000Hz" 148.500000 1920 2448 2492 2640 1080 1084 1089 1125   +hsync +vsync
Switchres: [ 37] 1920x1080 @ 59 : system mode
Switchres: [ 38] 1920x1080 @ 60* : ATI ADL timing "1920x1080_60 67.431000KHz 59.938667Hz" 148.350000 1920 2008 2052 2200 1080 1084 1089 1125   -hsync -vsync
SwitchRes: Found 25 custom of 38 active video modes
SwitchRes: Creating automatic specs for LCD based on current timings
SwitchRes: Monitor range 66375.00-68625.00,59.00-61.00,0.593,0.297,0.998,0.059,0.074,0.534,0,0,1080,1080,0,0
SwitchRes: [ 640]x[ 480]_[59=59.000000Hz] - locked
SwitchRes: [ 640]x[ 480]_(60=59.927620Hz) - locked
SwitchRes: [ 640]x[ 480]_(75=75.000000Hz) - locked
SwitchRes: [ 720]x[ 480]_[59=59.000000Hz] - locked
SwitchRes: [ 720]x[ 480]_(60=59.939049Hz) - locked
SwitchRes: [ 720]x[ 576]_(50=50.000000Hz) - locked
SwitchRes: [ 720]x[ 576]_[59=59.000000Hz] - locked
SwitchRes: [ 800]x[ 600]_(60=60.315285Hz) - locked
SwitchRes: [ 800]x[ 600]_(75=75.000000Hz) - locked
SwitchRes: [1024]x[ 768]_(60=60.003723Hz) - locked
SwitchRes: [1024]x[ 768]_(75=75.027496Hz) - locked
SwitchRes: [1152]x[ 648]_(50=50.000000Hz) - locked
SwitchRes: [1152]x[ 648]_[59=59.000000Hz] - locked
SwitchRes: [1152]x[ 648]_(60=59.934666Hz) - locked
SwitchRes: [1280]x[ 720]_(50=50.000000Hz) - locked
SwitchRes: [1280]x[ 720]_[59=59.000000Hz] - locked
SwitchRes: [1280]x[ 720]_(60=59.934666Hz) - locked
SwitchRes: [1280]x[ 800]_(60=59.809868Hz) - locked
SwitchRes: [1280]x[1024]_(60=60.019699Hz) - locked
SwitchRes: [1280]x[1024]_(75=75.024391Hz) - locked
SwitchRes: [1600]x[ 900]_(60=60.000000Hz) - locked
SwitchRes: [1680]x[1050]_(60=59.954086Hz) - locked
SwitchRes: [1776]x[1000]_(25=50.000000Hz) - locked
SwitchRes: [1776]x[1000]_[29=29.000000Hz] - locked
SwitchRes: [1776]x[1000]_(30=59.938667Hz) - locked
SwitchRes: [1776]x[1000]_(50=50.000000Hz) - locked
SwitchRes: [1776]x[1000]_[59=59.000000Hz] - locked
SwitchRes: [1776]x[1000]_(60=59.938667Hz) - locked
SwitchRes: [1920]x[1080]_(25=50.000000Hz) - locked
SwitchRes: [1920]x[1080]_[29=29.000000Hz] - locked
SwitchRes: [1920]x[1080]_(30=59.938667Hz) - locked
SwitchRes: [1920]x[1080]_(50=50.000000Hz) - locked
SwitchRes: [1920]x[1080]_[59=59.000000Hz] - locked
SwitchRes: [1920]x[1080]_[60=59.938667Hz]
   rng(0): 1920 x1080_59.938667p 67.431000 [fract] scale(5, 4, 1) diff(0.00, 17.87, 0.3013) ratio(5.000, 4.821)
SwitchRes: [captcomm] (1) horizontal (384x224@59.637405)->(1920x1080@59.938667)
SwitchRes: Modeline "1920x1080_60 67.431000KHz 59.938667Hz" 148.350000 1920 2008 2052 2200 1080 1084 1089 1125   -hsync -vsync
Switchres: saving    ATI ADL timing "1920x1080_60 67.431000KHz 59.938667Hz" 148.350000 1920 2008 2052 2200 1080 1084 1089 1125   -hsync -vsync
Switchres: updating  ATI ADL timing "1920x1080_60 67.431000KHz 59.938667Hz" 148.350000 1920 2008 2052 2200 1080 1084 1089 1125   -hsync -vsync
Direct3D: Configuring adapter #0 = AMD Radeon HD 7800 Series
Direct3D: Adapter has Vendor ID: 1002 and Device ID: 6819
Direct3D: First scanline: 41, Last scanline: 1121, Break scanline: 1101, Delay scanline: 266
stream_buffer_size = 18432
DirectSound: Primary buffer: 48000 Hz, 16 bits, 2 channels
Input: Adding mouse #0: HID-compliant mouse (device id: \\?\HID#VID_093A&PID_2510#7&326ad39e&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding lightgun #0: HID-compliant mouse (device id: \\?\HID#VID_093A&PID_2510#7&326ad39e&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
unzip: opened archive file E:\Users\Public\mame roms\captcomm.zip
unzip: found E:\Users\Public\mame roms\captcomm.zip ECD
unzip: E:\Users\Public\mame roms\captcomm.zip has no ZIP64 ECD locator
unzip: read E:\Users\Public\mame roms\captcomm.zip central directory
unzip: closing archive file E:\Users\Public\mame roms\captcomm.zip and sending to cache
unzip: found E:\Users\Public\mame roms\captcomm.zip in cache
Switchres: restoring ATI ADL timing "1920x1080_60 67.431000KHz 59.938667Hz" 148.350000 1920 2008 2052 2200 1080 1084 1089 1125   -hsync -vsync
ATI/AMD ADL close
Foxhole
  • Last login:April 11, 2024, 04:05:15 am
« Reply #3 on: July 07, 2017, 11:03:22 am »
Change "Power Management Mode" to "prefer maximum performance" on the Nvidia control panel, it's in the "Manage 3d Settings".
inv
« Reply #4 on: July 08, 2017, 03:18:01 pm »
Thanks but no effect, I reinstalled videocard driver and no use.
