Author Topic: R89 e rr3  (Read 3029 times)
Lawndart
  • Last login:December 05, 2017, 02:25:24 pm
  • Analog (mostly)
R89 e rr3
« on: June 13, 2017, 09:04:23 pm »
Hi All,
My R89 is working fine however I get E rr3 displayed momentarily when it turn it on.
In service mode, Er r3 displayed on the CCC.
If I clear the code, it returns immediately when I switch from service to on mode.
I have searched, but no avail.
Thoughts?
Ken Layton
  • Guru
  • Technician
Re: R89 e rr3
« Reply #1 on: June 13, 2017, 10:45:39 pm »
Error 3 means rom chip Z7 is bad inside the Central Control Computer. You may have to send it (the Central Control Computer board) out for repair.
http://rowejukeboxparts.com/product-category/central-control-computers/
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: R89 e rr3
« Reply #2 on: June 14, 2017, 05:39:19 am »
Ken is correct Z7 is defective, you could try replacing this program chip for another one before sending the board to a Rowe Ami specalist, it needs to be programmed for a R-89 jukebox or the digits on the display will be in the wrong location.
Regards
Alan
Alan Hood
ami-man
UK
Lawndart
  • Analog (mostly)
Re: R89 e rr3
« Reply #3 on: June 14, 2017, 03:56:19 pm »
Great - thanks guys!
ami-man
Re: R89 e rr3
« Reply #4 on: June 15, 2017, 09:19:57 am »
Hi Lastdart,
If you can not locate a chip in the USA I can supply you from the UK.
Regards
Alan
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
« Last Edit: June 15, 2017, 09:21:28 am by ami-man »
Lawndart
  • Analog (mostly)
Re: R89 e rr3
« Reply #5 on: June 28, 2017, 07:59:29 pm »
Contacted Bruce at http://rowejukeboxparts.com
He sent me a new EPROM.  I have not installed it yet as all seems to be functioning fine.
Wait or install??  'Tis the question.
