Author Topic: Tube screen becoming blurry after minutes on.  (Read 1426 times)
Dacasks
  • Last login:February 09, 2021, 09:30:30 pm
« on: April 29, 2017, 08:41:11 am »
What it could be? Caps? Anyway to solve it?  It's a JVC broadcast monitor. My PVM blew and I can't find any technician to repair it :/
grantspain
  • Last login:Yesterday at 06:08:21 pm
Re: Tube screen becoming blurry after minutes on.
« Reply #1 on: April 29, 2017, 10:06:34 am »
do you mean focus is drifting?
if so then either flyback focus pot just needs a tweek  or is faulty,bad connection in crt socket or bad tube
Dacasks
« Reply #2 on: April 30, 2017, 01:44:52 pm »
Hi, thanks for answering!
I wouldn't say the focus is drifting... more like the image losing it's sharpness.
buttersoft
  • Last login:April 21, 2024, 08:06:32 am
  • Is running at 15kHz
« Reply #3 on: April 30, 2017, 08:14:18 pm »
This happens as flybacks age, sometimes. With arcade flybacks, anyway. Cracks in the casing or insulation breakdown mean that as things warm up the focus swims a bit. In some cases the image will be stable, and always in the same place - so you leave the cabinet on for 5-10mins and adjust the focus for that point. Other times the flyback will settle on a different point each time, and there's nothing you can do but adjust the focus every time you turn the cab on, but after it warms up - assuming this is the problem. It sounds like it, but this a broadcast set so I can't say for sure.
Some flybacks become a fire hazard as this gets worse, be aware.
