Author Topic: Speaker hole/grill/slot options  (Read 5116 times)
ugleymatt
  • Last login:October 11, 2022, 12:13:37 pm
« on: April 10, 2017, 07:03:28 am »
Hiya,
Thinking about my speakers for my bartop build. I had planned on using a speaker grill and surround for the speakers but i don't think this really fits with the style of the rest of the build, so ditching that idea. I guess the options are drilling holes, routing slots or something else?
What have you done, how did you do it, and would you recommend it? Drilling holes would be easier i would assume using a pattern,routing a slot seems like a tricky thing to get correct?
Titchgamer
Re: Speaker hole/grill/slot options
« Reply #1 on: April 10, 2017, 09:04:51 am »
Slots aint that difficult really.
But the skys the limit really.
You can drill holes, cut shapes/patterns/slots, cover them with grills/meshs etc.
sealcouch
  • Last login:October 19, 2025, 07:08:59 pm
« Reply #2 on: April 10, 2017, 09:55:51 am »
As someone with a harbor freight router that makes me fear for my life every time it's turned on, I choose to drill holes.
romshark
  • Last login:November 13, 2025, 05:36:05 pm
  • Arcade and Robotics enthusiast
« Reply #3 on: April 10, 2017, 12:35:46 pm »
I prefer slot-style myself for my speakers.
I do this by drawing a circle where the speaker is going to go (using something round, like a cup or a can.) Then, I figure out the distance from the bit to the edge of the base of my router. Using this measurement, I draw straight lines that distance away from each intended speaker slot.
When it comes time to route, I clamp a straight piece of wood on the line. I hold my router against this wood edge and cut a nice, straight slot in the circle. Move the wood "guide" to the next line, and repeat.
You might want to make the slots smaller than your speaker. That way, if the speaker area and the marquee light are together, light won't leak out of the speaker slots.
Here's an example from when I did my speakers, as well as the rear top vents of my cabinet.
ugleymatt
« Reply #4 on: April 10, 2017, 06:12:56 pm »
THank you for that example!! it looks straight forward enough. I will give it a try on some scrap. Good advice on keeping the size smaller than the speaker!
  • Last login:Today at 02:18:20 pm
« Reply #5 on: April 10, 2017, 09:43:40 pm »
This.  That's exactly how I felt when I used mine last year.  She got the job done, but I was scared for sure.  Those things should be illegal.
But got a Ryobi for Christmas last year and can't wait to use it this summer.  My life is worth more than saving a few bucks on a cheap router.
DeL
morton
  • Last login:July 23, 2021, 09:36:59 am
« Reply #6 on: April 12, 2017, 09:41:59 am »
I love the look of slots, but some of those are too small.
I hear some people complain about audio quality in arcade cabinets... This is why. Those slots are clean and nice, but have a detrimental effect on the sound. Blocks the front radiating sound from exiting properly. This will change frequency response and the speakers ability to accurately reproduce sounds. It may not matter for bleeps and bloops, but can assure you, it can sound better. There is actually a portion or audio community who uses slot loading to their advantage, but they do so intentionally with an ability to get certain results. Bigger slots are better, and you want to restrict as little as possible... So go with thick slots with more than 50% sound travel allowed. The more open the better, but figure most will have to balance aesthetics with these principles. I've never tested this in an arcade cabinet, but have in HiFi, and was always something that stood at back of my mind regarding cab builds...
... and I like slots. Not hating. Just throwing out ideas.
ugleymatt
« Reply #7 on: April 12, 2017, 06:48:33 pm »
When you say 50%, do you mean that for your speaker size you effectively want to make sure that at least 50% of the speaker is showing. So either with wider slots or more of them
  • Last login:December 18, 2025, 07:06:30 pm
« Reply #8 on: April 12, 2017, 08:21:41 pm »
I made a template and drilled holes. So much easier.
morton
« Reply #9 on: April 13, 2017, 09:16:13 am »
Speakers are black magic. They can "just work" or you can get them to sound good.  :soapbox:
I like that you chose to do audio the hard way, and not just slap a PC speaker in there... not that there is anything wrong with that.
Ideally, we don't want to block any sound. If we block it, we stop sound from traveling unimpeded. Blocking the front sound wave of a speaker can be good or bad. The speaker is a piston making pressure, when you have a small opening, the pressure builds up and affects the speed of the air that leaves the opening. From an audiophile standpoint, this is bad if we are working with speakers that already have an inherently good sound. One time we use this is when we want to shape the sound of the speaker, as we do with bass woofers in open baffles... It's a big read, but if you google "Nelson Pass Slot Loaded Woofer" you will find a white paper on his research. He's the man when it comes to audio. Basically bass speakers in a box is what you're all used to. Bass outside a box is tricky, sounds different, and requires different approaches.
Now the purpose of slot loading is to get better bass. What makes Mr. Pass' example work, is that he is trying to boost low frequency. While this sounds good to us, we have to remember that most of us use a coaxial speaker (high and low together). So blocking the speaker 50% may help us get a bit better bass (minimal when talking about 3-4" speakers) but at the price of blocking out the high frequency of the tweeter. In an arcade cabinet, this seems counterintuitive. That said, anyone adding a mild subwoofer (won't be hammering 20z) to their cabinet could use this principle to their advantage - not needing to make a box inside another box. But that is for another day.
The reason car speakers work so well in arcade cabs is that they are 1) cheap, 2) small, 3) sensitive (4ohm vs 8 ohm, another whole lesson) and 4) they are found in doors, dashes and rear decks - big leaky enclosures. You will notice that some car speakers have a high QTS spec under the Thiele-Small parameters. What makes a high QTS speaker good is that they have a somewhat exaggerated bass response, which means that when put in a big leaky box (which hurts bass), the speaker will still have good bass response.
So it's not to say that 50% of your opening is wrong. If thats what looks good and you're happy with it, then no problem. Depending on your speaker, it may sound better, it may not. Your ears will have to be the judge, there is not right or wrong way to do it... just a compromise is usually required. Nintendo Cabs have them sexy slotted speaker grilles that I love to look at, but the audio guy in me is whispering in my ear "that better be bass only"  :lol If you want a cab that will have great sound, it's not necessarily rocket science, but it's not just a matter of throwing a speaker in a hole.
Caution : It has occurred to me in writing this that some games may have been designed or modified to accommodate a speaker mounted in such a way. Could explain why some games are so high pitched - they expected those sounds to be attenuated by speaker grill. Or I am just overanalyzing it... totally possible, but felt the need to caution you
I am working on an audio tutorial for arcade cabinets that I hope can help folks in picking audio parts etc for their cabs. I cannot say when it will be finished, but hope its something I can contribute to the community.
Feel free to PM with more questions/clarifications, as it's possible I just made this worse  :lol
ChurchOfSolipsism
  • Last login:May 09, 2023, 01:43:39 pm
« Reply #10 on: April 18, 2017, 05:54:30 am »
Very interesting points, morton - I'd never really thought about the way these slots influence the sound you get from your cab. I'll be looking forward to your audio guide!
Titchgamer
« Reply #11 on: April 18, 2017, 07:58:48 am »
Sounds interesting Morton, I look forward to seeing that when you do it.
