Author Topic: MegaTouch XL Extreme Touchscreen  (Read 3280 times)
tandrews
  • Last login:November 13, 2019, 08:10:54 pm
« on: January 06, 2017, 03:31:46 pm »
I finally got this stupid XL to boot. Then the stupid key doesnt work...quick patch of megacdll later, the game boots...but the touchscreen doesn't work.
I can press the button to get to service, but nothing happens. I've reseated the connectors and verified the controller is getting power.
Any suggestions? PS I plan to patch the megacdll files for as many versions as I can. If you're interested, let me know.
lilshawn
  • Moderator
  • Last login:Yesterday at 07:36:40 pm
Re: MegaTouch XL Extreme Touchscreen
« Reply #1 on: January 06, 2017, 04:27:51 pm »
if you press the screen can you see the green light on the controller box get brighter as you press it?
IE it should be on, but go brighter if you press the screen.
if it does this, it may just need to be recalibrated. next to the service button is a calibration button. if you press this in the game select screen, it will bring up some marks you press to calibrate the screen.
if the machine ignores the press, you might have a data cable issue. make sure the cable from the controller box is plugged into the motherboard's com1 port.
if it accepts the calibration, but in testing the mark doesn't go where it's supposed to or gets stuck in one spot, you may have an issue with the touch overlay.
tandrews
« Reply #2 on: January 06, 2017, 04:51:34 pm »
I'll try calibrating it.
