Author Topic: MAME buttons reset every time I launch Maximus Arcade  (Read 5966 times)
misterboom
  • Last login:December 21, 2016, 09:34:00 am
« on: December 20, 2016, 10:57:31 pm »
I'm running whatever the final/latest version of MA is, and am on Windows 10.
When I customize all of the buttons within the MAME app everything is fine, but as soon as I launch Maximus Arcade they reset to the defaults.
I read a couple forums saying this was a known issue with a few versions of the beta, but was fixed in like version 6. The problem is the only version I can find to download is the final one.
Is there any solution for this? Or a download of a previous beta build?
Please help! :)
bvander
  • Last login:January 11, 2017, 10:39:54 am
Re: MAME buttons reset every time I launch Maximus Arcade
« Reply #1 on: January 10, 2017, 11:14:19 am »
I don't have an answer for you on that.  I have a somewhat similar issue where I have added Emulators to MA and every time I reboot the computer, my preferences reset to the default settings and I have to re-config the new emulators.  It's annoying.  I have an X-Gaming unit that runs MA on it.  I reached out to the company and this is what I was told to do:
"There is a batch file that re-writes the default.ini file on boot to keep the PC from ever not starting correctly due to it getting corrupted. You could just edit it to not do that if you know how, it's the startup.bat file found in the Max 2.10 folder.
Alternatively, this update would change how that works:
Instructions: X-Arcade Cabinet Software Upgrade - New Features"
I am going to try the update first and see how that goes.
I have no idea if that default.ini file is helpful to your issue or not, but thought I'd let you know
Good luck with your issue.
Titchgamer
« Reply #2 on: January 10, 2017, 11:47:21 am »
No help to you but I dropped MA last year and went to Hyperspin.
Much better and theres support still for it!
yabadaba
  • Last login:July 11, 2017, 09:56:03 pm
« Reply #3 on: June 03, 2017, 08:44:28 pm »
Generally a lot of these kinds of  issues of emulators and/or front-ends forgetting settings can be resolved by setting the executable to run as an administrator. This seems to be especially true in windows 10. If you haven't given up already and moved on to some other front-end, this would be low hanging fruit.
