Author Topic: Happs arcadevga knock off does 15k and 25k!!  (Read 2831 times)
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« on: January 20, 2004, 10:37:39 am »
well I am getting ready to build a cab for a buddy using a gauntlet darklegacy podium with a 39" med res monitor and well how do I use a 25k monitor? well I was at happs site and found this pricy little card that does both 15k and 25k...now can ya setup dual? i dunno.. but the podium has a sweeet 39" neotec and 4 perfect 360 jstix so I cant wait to get my game on ;)
AMIGrAve
  • Last login:June 11, 2024, 03:56:35 pm
Re:Happs arcadevga knock off does 15k and 25k!!
« Reply #1 on: January 20, 2004, 05:42:42 pm »
I also have a 25Khz monitor in my Virtua Fighter, mine can be switched from 25Khz to 15Khz, perhaps yours too.
Personnaly, I would like to use the 25Khz frequency as such as the 15Khz, but I don't know yet how that will be possible.
The reason is that I like shoot'em ups, and most of them are vertical game wich resolution is around 224x384, and as the 25Khz resolution is 512x384 that is perfect, no need to do a rotative monitor, but I don't know if I can make a switch 15Khz <-> 25Khz and use it while the monitor is powered, I son't know if it can damage the monitor.
Can you point an url ?
tom61
  • Last login:September 18, 2017, 12:46:56 am
« Reply #2 on: January 20, 2004, 06:00:25 pm »
Did you mean this:
http://www.happcontrols.com/index.html?http://www.happcontrols.com/monitors/96058300.htm!
That is just a scan converter, and at $225, a fairly expensive on too.
desmatic
  • Last login:June 25, 2006, 02:25:53 pm
    • Easy MameCab
« Reply #3 on: January 21, 2004, 01:32:51 am »
 Properly scales and converts to the desired timing and output
This is the line worth noting.  ArcadeVGA doesn't scale or convert.  Conversion=stretching=crappy.
delta88
« Reply #4 on: January 22, 2004, 01:30:17 am »
yeah but the arcade vga doenst do 25k either!!! ;p so until it does this is what med res monitors use.. ;)
any other suggestions?
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #5 on: January 22, 2004, 12:25:59 pm »
I'm pretty sure that AdvanceMame is a do-able solution for running a 25khz monitor (one option - take it or leave it).
