Author Topic: Is this monitor too good to be true? (Ebay decision time)  (Read 25228 times)
ed12
Re: Is this monitor too good to be true? (Ebay decision time)
« Reply #120 on: October 17, 2016, 07:10:08 pm »
ya I thought about painting the borders in. but the owner said no
so no it is
ed
lilshawn
  • Last login:October 22, 2025, 11:23:16 am
« Reply #121 on: October 17, 2016, 08:44:54 pm »
 :dunno
I does what they tells me.
ed12
« Reply #122 on: October 17, 2016, 09:06:07 pm »
I think on the gt golf I will do the paint trick though.:):) just to piss him off
ed
ed12
« Reply #123 on: October 17, 2016, 09:54:35 pm »
the thing I am going to like about the gt6 is it fits into a h5 cab "edge to edge"
so I used the vesa mounts to do it
thank you dynamo
the pga's I had to cut and build wood prop mounts (which I do not like the idea off)
reason is the person moving these things thinks he is moving a battle ship (true)
ed
JDebler
  • Last login:September 24, 2023, 05:59:57 pm
« Reply #124 on: November 26, 2016, 03:13:48 pm »
Checking in on this...new guy here and doing my first mame arcade cabinet build but the project is halted not knowing the size of the monitor I can use.
Are there any more updates on the heat and performance for this panel?
Also...are you guys mounting them horizontally or vertically?
Guywiththegun
  • Last login:February 17, 2020, 12:00:21 pm
« Reply #125 on: November 28, 2016, 03:02:16 pm »
I couldn't be happier with it. I'm mounting it horizontally with wood. I have it leaning on two brackets and re-enforced with wood going across the cab, using the brackets on the monitor. Heat was a little concerning at first. I had glass leaning on it and the glass itself would get pretty hot after 30 minutes or so. I mounted two big (silent) computer fans behind it (blowing upward at an angle towards the back). No issues with heat since.
If this is still available I'd grab it. Just get the fans. I payed like $15 for them and just mounted them quickly with a strip of wood and L brackets. I wired them directly to 12v lines of some molex adapters I'm using for LEDs. Easy fix.
Jakobud
  • Last login:Yesterday at 01:03:36 am
« Reply #126 on: November 30, 2016, 10:50:43 am »
I have a 23.1" 4x3 LCD that's been sitting in my closet a few years. Been waiting to build a Mame cabinet with it. But I'm not sure if maybe I should just sell it to someone on byoac or not...
Thormus
  • Last login:February 14, 2017, 06:18:34 pm
« Reply #127 on: December 05, 2016, 12:41:04 pm »
I just purchased one. Hoping for the best. Going to be putting this into a converted 4 player stand up cabinet.
