Author Topic: I-PAC 2 (2015 version) acting crazy  (Read 1879 times)
releasedtruth
  • Last login:April 11, 2018, 12:06:49 am
  • Projected Nexus
« on: July 09, 2016, 09:51:11 am »
Background: Built a cab 10 years ago with I-PAC 2 installed. Upgraded PC (HP Elite 8200), one one wouldn't work in Win7x64 so I ordered a new model. Simple, right?
Well, connected it up, plugged it in and it took over the keyboard. If you open the start menu, browser, anything with a text field, it spams the '2' key at high speed or cycles open fields. Can't program it, can't use the computer until you unplug. I've tried
1) All other USB ports on the PC
2) Checked firmware is latest on I-PAC
3) Multiple USB cables
4) Confirmed all connections and grounds
5) Checked all microswitches
https://goo.gl/photos/GWMHiKANENp741Rv9    (video of what it does in Winipac)
Unplug and PC back to normal. Advice? Thanks!
RT
wemr97dl
  • Last login:October 16, 2025, 04:44:42 pm
  • KEEP GOING!
Re: I-PAC 2 (2015 version) acting crazy
« Reply #1 on: January 19, 2017, 04:37:51 am »
HAVING THE SAME ISSUES DID YOU FIGURE OUT WHAT WAS GOING ON??
yamatetsu
  • Last login:Today at 02:04:12 pm
  • Just because.
« Reply #2 on: January 19, 2017, 05:26:00 am »
Sounds like you connected one or more microswitches to NC instead to NO, this means there are constantly sent keypresses to the IPAC until you press the button. Release the button, keypresses are sent again.
wemr97dl
  • KEEP GOING!
« Reply #3 on: January 19, 2017, 07:20:33 am »
Misread the original post, i have no keystrokes at all from my keyboard. When I hit esc to exit emulator it opens the windows menu, if I open up an explorer window or anything else I can't type anything and all my keystrokes act like short cut keys, opening windows ext. always happens after I launch hyper spin or win ipac . Did a system restore to previous date everything was fine again until I ran hyper spin same thing happened
DolansCadillac
  • Last login:April 07, 2021, 05:51:14 pm
  • Can't buy a bucket
« Reply #4 on: January 19, 2017, 11:18:26 am »
That sounds like the kind of behaviour you'd get if you were holding down Ctrl (ctrl+esc opens the start menu, plus all kinds of Windows shortcuts). Check the wiring on P1 SW1 maybe?
Also to rule it out, you could check http://www.keyboardtester.com/ to see if anything's being hit.
« Last Edit: January 19, 2017, 11:22:42 am by DolansCadillac »
Titchgamer
« Reply #5 on: January 19, 2017, 11:41:00 am »
With these kind of probs I always suggest opening the Winipac utility and see what buttons are being "pressed"
This will help you narrow down the problem to individual buttons.
wemr97dl
  • KEEP GOING!
« Reply #6 on: January 19, 2017, 10:24:53 pm »
tried the winipac and didn't show any buttons pushed, I'll try a keyboard test first chance I get, thanks
wemr97dl
  • KEEP GOING!
« Reply #7 on: January 20, 2017, 04:01:00 pm »
Found it was a stuck key,thanks
