Author Topic: Gamepad -> USB converters ... do they work?  (Read 2444 times)
bigmoe
  • Last login:July 16, 2004, 04:17:54 pm
  • I forgot my mantra!
« on: January 16, 2004, 12:34:36 pm »
Anyone use ever use one of these http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3072224244&category=3677 with a MS Sidewinder gamepad hack?
b
What was that again?
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:Gamepad -> USB converters ... do they work?
« Reply #1 on: January 17, 2004, 06:47:23 pm »
It won't work with a MS Sidewinder, only the old four button pads.
CthulhuLuke
  • Last login:May 22, 2025, 01:03:42 am
  • old school
    • CthulhuLuke's Arcade Parodius
« Reply #2 on: January 17, 2004, 08:54:01 pm »
Do you know that from experience or just because its a gameport Tom?  I would think it would just transfer exactly what was going from the gamepad to the usb in a special driver, but maybe not.  If it just transfered directly from gameport to USB, it would do sidewinders perfectly, but if it only had 4 button input, that'd suck
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #3 on: January 17, 2004, 09:53:11 pm »
Well the item's description says, "Supports conventional analog game controllers." so I would bet it doesn't support the sidewinder. The sidewinder transmitted the joystick's info (buttons down, joystick position) to the pc via the midi port (same connector as the gameport).  This is totally different from the way old analog joysticks worked.
tom61
« Reply #4 on: January 18, 2004, 04:13:00 pm »
Many have tried it, it doesn't work.
It shows up as a USB gamepad. It decodes the resistor values then sends the USB HID command that means the same. Which is why it has a switch for gamepad/joystick/wheel.
bigmoe
« Reply #5 on: January 18, 2004, 06:18:47 pm »
I received this response from one of the sellers:
"It won't support that b/c MS SIDEWINDER is a digital controller."
It made sense to me that it won't work once I remembered that the pad needs a special driver, so there is something more going on than simple resistor decoding.
Dripht
  • Last login:June 24, 2009, 10:18:37 pm
« Reply #6 on: June 23, 2004, 07:49:05 pm »
I've seen a few of these questions around the internet and I'm starting to wonder why you'd want to "convert" a gameport sidewinder to a usb one in the first place?
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: June 24, 2004, 06:57:40 am »
Just off the top of my head:
1) Gameport sidewinder is probably a fairly easy (or well-documented) hack with lots of buttons
2) Many (most?) new motherboards no longer have a gameport.
FWIW.
Grasshopper
  • Last login:March 04, 2025, 07:13:36 pm
« Reply #8 on: June 24, 2004, 08:00:18 am »
I think it would be better to hack a Playstation pad and use a Playstation to USB converter with that.
Alternatively, you could hack an Xbox pad. They are based on a slightly modified USB interface. I learned recently that all you need to do to use an Xbox pad with a PC is to make/buy an adaptor cable and download a driver from the internet.
Mr. Dude
  • Last login:March 03, 2019, 05:12:50 am
  • Hi...
« Reply #9 on: June 24, 2004, 09:30:35 am »
They make a super joy box for PS2 and XBOX pads and I was thinking of trying it.  I'd love to be able to play games like Halo and Unreal Tournament with an Xbox pad.
