Author Topic: Rowe Juke Left Channel Full On  (Read 1563 times)
Wrubel
  • Last login:May 01, 2016, 11:32:04 pm
« on: April 18, 2016, 01:43:20 pm »
I just picked up a cd-100a Rowe Juke box. It was hooked up to external speakers where it was at. I hooked up the internals and the right channel works fine and is controlled by the volume switch ok. The left channel stays full on and is not controlled by the volume at all.
Has anyone seen this before and/or could help?
Wrubel
Re: Rowe Juke Left Channel Full On
« Reply #1 on: April 20, 2016, 10:36:24 pm »
Thanks you for all who viewed this thread. I found the answer after tweaking my search criteria a few times.
I found the answer here:
http://forum.arcadecontrols.com/index.php?topic=130538.0
I had already found out about the e1 and e7 connections, but I did not have a jumper in the jumper volume section.
