Author Topic: PS2 Network Adaptor  (Read 3507 times)
J_K_M_A_N
PS2 Network Adaptor
« on: December 30, 2003, 11:09:29 am »
Does anyone know if the PS2 Network Adaptor works if you connect it to a network hub and use Internet Connection Sharing with Windows 2000? I don't want to have to come downstairs and unplug the cable modem from the computer and connect it directly to the PS2. I have a network cable running upstairs already and it is connected to a 100Mbps hub that connects to my 4 other computers. I use my Windows 2000 computer to connect directly to the cable modem and then use Internet Connection Sharing for the rest of the computers. I have searched the web and I thiknk I found a site saying it will work but I want to be sure. BTW, the hub is just a hub, not a router. I know I should get a router but I don't want to so there! Thanks for your help.
J_K_M_A_N
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
Re:PS2 Network Adaptor
« Reply #1 on: December 30, 2003, 12:35:46 pm »
I don't see why it wouldn't work.  You should be fine.
If no one feeds the trolls, we're just going to keep eating your goats.
J_K_M_A_N
« Reply #2 on: December 30, 2003, 10:12:31 pm »
I believe it will work also, but I would like to know if anyone out there has tried it and weather or not it works for sure. I don't want to waste $35 if I don't have to. I don't want it if I have to run downstairs and swap cables when I want to use it. Thanks again.
J_K_M_A_N
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #3 on: December 30, 2003, 10:45:22 pm »
Hey, was just passing by, and I decided to share this information with you:
http://www.keypoint.com.au/knowledge.html?strid=1417
http://boardsus.playstation.com/playstation/NetworkAdaptorFAQ
http://boardsus.playstation.com/playstation/board/message?board.id=tmbo&message.id=1738
That 3rd link is a 1 page Forum Thread (I know you said "no-no" to the router idea, but in the last post somebody says they use a hub, so I guess if you wanted to, you ask them.  :-\ )
Hope I helped a bit
Later
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
eightbit
  • My cab is never done...
« Reply #4 on: January 03, 2004, 02:55:11 pm »
I have no PS2 experience but my xbox's work just fine doing it that way.
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« Reply #5 on: January 05, 2004, 11:13:45 pm »
When I owned a ps2 I used it with a switch and had no problems at all.
« Last Edit: January 05, 2004, 11:15:21 pm by Edgedamage »
Curls in the squat rack !?!?!
