Author Topic: RetroPi or PiPlay?  (Read 9629 times)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
RetroPi or PiPlay?
« on: May 23, 2015, 01:52:39 am »
Does it matter which way to go?  I just found out about this through the latest version of Make magazine which talks about PiPlay.  I have an RPi2 with PiPlay on it now.  Both use advmame 0.106 so it really wouldn't matter in terms of game support, correct?
I really like the web upload interface with PiPlay, makes it much easier to get the roms onto the system.
So far all the games I normally play it can handle.  However, some issues.
I have to setup the controls for each game, global controls don't take.
For many game the auto resolution doesn't work well so I have to manually set it.
1944 not working.  Though the rom I have is for 0.92 and up, but advmame is complaining about missing nffux.03.  That's for the earlier version of the rom.  I tried renaming the one file to that (nffu.03) no go.
Coin/start with an xbox controller doesn't always work for some reason.
Locke141
  • Never grow up.
Re: RetroPi or PiPlay?
« Reply #1 on: May 23, 2015, 07:42:52 am »
The fact that PiPlay is super easy to add roms is nice, but it's default front end is not the best looking. I think they added an official better looking front end as an option but I haven't messed around with it yet.
if you want to try RetroPie you may want to try the DietPi with RetroPie build. It use's a strict down versions of Raspbian for quicker boot times and better performance. It also comes with emulation station a good looking simple front end that fits the bill if your mostly using console games. There is a step by step here.
If you want more of an arcade feel then emulation station, Attract Mode now works on the PI. A member here is working on a DietPi, RetroPie, Attract mode, with GPIO joystick support and GPIO on off build. It looks very promising hopefully he will be ready to post a down load link to the community soon.
« Last Edit: May 23, 2015, 07:44:53 am by Locke141 »
  • Last login:Today at 12:47:05 am
« Reply #2 on: May 23, 2015, 08:36:23 pm »
Neither, to be honest.
  • Last login:Today at 11:27:39 am
« Reply #3 on: May 23, 2015, 09:38:11 pm »
Yup, that's going to change a lot of attitudes about the Pi when it's ready to go....
So close... so close....
Aceisback
  • Last login:February 04, 2021, 07:45:41 pm
« Reply #4 on: May 23, 2015, 11:51:37 pm »
Been using both for a while, they all have their quirks. I am using Retropie in my bartop and my 2 nano/mini arcades I am working on and have no real complaints. Since it is easy enough to to try different setups, I would try all of them including the DietPi that was mentioned earlier and see what works best for you.
Locke141
  • Never grow up.
« Reply #5 on: May 24, 2015, 12:56:30 am »
Agreed, it will also make all the xxx-in-one's arcade boards pointless.
Like with most free software, trying every thing that looks interesting is good advice. Just to be clear, DietPi is a lighter versions of the standard R-pi foundations OS. You don't need it to run Retropie, it will however free up more resources for Retropie and your emulators.
« Last Edit: May 25, 2015, 03:29:21 am by Locke141 »
ark_ader
  • I glow in the dark.
« Reply #6 on: May 24, 2015, 10:57:59 pm »
I tried Piplay and Chameleon and both do not work with a wired ethernet connection or the several wifi stick I have laying around.  I was going to use the Raspi for my cabinet project, but if it is going to be this much of a hassle then I will have to plumb for a PC or xbox.  They look nice but that is all.
Locke141
  • Never grow up.
« Reply #7 on: May 25, 2015, 12:56:05 am »
Are you sure you have a compatible wi-fi dongle?
A list of know compatible dongle.
http://elinux.org/RPi_USB_Wi-Fi_Adapters
Set up:
https://www.raspberrypi.org/documentation/configuration/wireless/
http://www.raspyfi.com/wi-fi-on-raspberry-pi-a-simple-guide/
« Last Edit: May 25, 2015, 01:17:24 am by Locke141 »
ark_ader
« Reply #8 on: May 25, 2015, 12:20:32 pm »
Set up:
Thanks for the list.  I have the Asus WL-167 and it was detected but no connection.  My pi is the first batch that came out so may be too old.  :D
It works now.  I had a senior moment, but I got better.  It's a side effect of looking at CRTs too close for many years.  I guess my parents were right about at least one thing.  :lol
« Last Edit: May 25, 2015, 08:26:07 pm by ark_ader »
