Author Topic: Raspberri Pi B+ and retropie  (Read 3519 times)
elPaulio
  • Last login:March 17, 2016, 01:36:24 pm
« on: April 12, 2015, 05:41:54 am »
Hi all
Newly registered here :)
Ive built myself a bartop arcade and not needed much help, until now!
Has anyone got any experience with setting up retropie (particularly retroarch) on the Pi?
Let me be a bit more specific - its going to be a long post... sorry in advance!
Ive started from scratch and got all the stuff fitted into the cab etc etc. build is basically done and im onto software config
Ive Installed Adafruit to map my joystick + 9 buttons to keypresses
Got the emulators = roms to work, no issues
Installed retropie
The emulationstation works fine, I was able to configure successfully the joystick and buttons first time
mame4all is working fine, all buttons mapped too
but neither of these use retroarch
now when I try and use snes or megadrive roms, they cant be controlled, or can, but some buttons are mapped, and some are not, and with the wrong function
So this is my joystick to keyboard mapping with Adafruit and directly connecting the buttons+stick to the GPIO pins
Joystick, up, left, right, down = always fine!
I have 6 buttons, which Im labelling A,B,C, X,Y,Z
and then 3 more buttons for start, select, and exit emulator
The keyboard map equivalent (tested with Adafruit and successful)
A= Enter
B= B
C= C
X= X
Y= Y
Z= Z
start button= 1
select button= 2
exit= 3
So, if I press the B button on the arcade, the screen will type a letter b out to the screen (they all work perfectly using the software and a text editor)
https://github.com/petrockblog/RetroPie-Setup/wiki/RetroArch-Configuration
Tries to help, but as below, the methods are not working properly in reality
My retroarch config file looks like this:
input_player1_joypad_index = 3
(I think this forces keyboard, but other values dont seem to work anyway)
input_player1_b = b
input_player1_a = enter
input_player1_y = y
input_player1_x = x
input_player1_l = c
input_player1_r = z
input_player1_start = 1
input_player1_select = 2
input_exit_button= 3
The above doesnt work whether I define it in the /opt/retropie/configs/all, or the /opt/retropie/configs/snes or megadrive directories
In fact, If I put it in the ‘all’ directory, everythings stops working altogether and I cant even use a keyboard to escape
Ive also tried hitting F1 in game and getting a menu where I can configure controls. but when I try that, it just waits for a keypress from somewhere forever (until I hit Enter to skip)
The problem seems to be with retroarch, but I cant quite figure it out?
Again, apologies for the long post, but im losing the will to live with this configuration as ive spent hours trying to figure it out.
Thanks in advance
edekoning
  • Last login:November 10, 2022, 02:21:38 pm
Re: Raspberri Pi B+ and retropie
« Reply #1 on: April 13, 2015, 11:39:43 am »
Just started looking into retroarch myself, and I ran into the exact same issue. The GUI does not support changing keyboard key mappings, so you need to do it in the config file :( Unfortunately, it is not specified anywhere what all the supported key names are. So I decided to check the code, and found the complete list of key names: https://github.com/libretro/RetroArch/blob/master/input/input_keymaps.c
So in your case it should be:
input_player1_b = b
input_player1_y = y
input_player1_x = x
input_player1_l = c
input_player1_r = z
input_player1_start = num1
input_player1_select = num2
input_exit_button= num3
elPaulio
« Reply #2 on: April 18, 2015, 06:22:36 am »
Just got around to having a go on this. Perfect.
num1, num2, etc. was where I was going wrong.
I had previously tried playing with the F keys, but found that the default mapped keys were also doing the same thing.
So where F2 I mapped as, 'select', it would also 'Save' as it was getting the global config - which I thought the local cfg file in the emulator folder would take priority...
Turns out, I had an #include global config at the top of the file (I didnt really know what it did, so I left it)
Ive swapped back to num1, num2, and 3 now as per your post.
input_player1_joypad_index - I still dont know what this does, but it works without it, so im guessing its Joypad/controller exclusive, so ive left it blank now
Thanks for the help, very much appreciated :)
