Here are the first post regarding the building details for this project.
The projects goals:
1. 256 Multi-touch Windows 8.1 + OSX and Linux support
2. Lightpen drawing support
3. Jamma support: Real Arcade PCBs are supported as well as JPACs
4. DMX light control
5. Remote control
6. Future Pinball
Where to start...
Hardware used:
Multi-Touch Parts:
IR Led Strip 850 nm, 120°
Acrylic W/Metal particles
Regular Acrylic for Diffuser holder
PS3EYE
IR Filter 750nm
M12 Mount
M12 Lens (170 Degrees)
Display:
Samsung
Model Code: LE40A559P4CXXE
Type No: LE40A559
Diffuser sheet
LCD Panel
LCD Back-light
Power board
Video Board
LCD Board
Remote control board
IR-Light Pen:
LED from old DVD Remote Control
Standard Marker
AA Battery
Switch from old Keyboard Receiver
Arcade Parts:
Sanwa JLF-TP-8YT x2
Sanwa OBSF-30 x12
Sanwa OBSF-24 x 2
CPU Comparable Electronic Coin Acceptor (TW-130)
Modded CD-ROM audio cable
J-PAC
Jamma Harness Assembly
16 Wire control cable (6 Meters) (55-721-85)
15 Pin Dsub Male x2 (44-055-69)
15 Pin Dsub Female x2 (44-055-10)
15 Pin Dsub Enclosure x4 (44-093-63)
Metal Parts:
Custom Screen Frame
Custom ATX Power Bracket
Custom Video and Power Card Mounting Bracket
Custom Rib Card Mounting Bracket
Custom Joystick Panel x2
Table legs x4
Wood and misc:
MDF 2.1 mm Full plate x2
Wood Screws (lots of different sizes and length)
Powerbox
Power clamps
Cable channels
Wire strips
Mounting bolts large with washers and nuts x4
Mounting bolts small with washers and nuts x16
screw holders x 14
Plastic gloves
Molex splitters x3
![](http://i.imgur.com/dPpsgW3.jpg)
![](http://i.imgur.com/xeVePlL.jpg)
![](http://i.imgur.com/ZZUbaG3.jpg)
![](http://i.imgur.com/Hr9TlOS.jpg)
Choosing your display:
Here are the important factors:
Make 100% sure the Display you're choosing has NO FFC issues. The LCD panel should have a 178 degree viewing angle or more. A back-lit panel would be preferable. Large LCD frame holder preferable.
Since I never really had taken apart any LCD panels before, I wanted to do some research and practical testing the check out the general idea before taking apart the Samsung panel I wanted to use for the table. The testing started with an old 14" PC monitor which was pretty easy to dismantle the LCD on.
![](http://i.imgur.com/ZTrAFMU.jpg)
![](http://i.imgur.com/mWSO4TP.jpg)
![](http://i.imgur.com/EdX49xj.jpg)
![](http://i.imgur.com/RVp9yWX.jpg)
After a successful test I wanted to practice the procedure on a larger screen before dismantle the Samsung TV and its LCD panel. Lucky for me a friend of mine had a couple of broken LCD TVs lying around that I was given (One 40" with cracked panel and One 32" that wont power on)
![](http://i.imgur.com/jC62SJj.jpg)
![](http://i.imgur.com/3xL9nBD.jpg)
The principle was of cause still the same, however I had to be really careful with the 40" LCD panel once IŽd taken it apart. After yet a successful test I felt comfortable to take the Samsung TV I was going to use apart.
After taking the TV apart and disseminating the LCD panel I did a quick test to make sure The TV and LCD panel still worked.
![](http://i.imgur.com/ntqZ50K.jpg)
It was then time to seriously start on the woodwork's. I drafted up the basic dimensions for the table. Top plate 150x90cm. Left and right sides 60x30 Front and back 60x70. Then I had to start to party assemble everything to continue my testing.
![](http://i.imgur.com/Mv2fEdB.jpg)
![](http://i.imgur.com/u7vmsXe.jpg)
The Next step was to check if the back-light was strong enough to light up the screen properly from a distance and not create any dark spots. I placed everything upside down on my cheap glass table I picked up at finn.no.
![](http://i.imgur.com/wdAygVE.jpg)
On my first power up I didn't bother to mount the diffuser ect which gave this result.
![](http://i.imgur.com/Ivim7OZ.jpg)
I then decided to mount the diffuser and wire everything in. This finally gave a satisfactory result.
![](http://i.imgur.com/t1iVfpz.jpg)
![](http://i.imgur.com/iaQfM2M.jpg)
![](http://i.imgur.com/YdOSoD0.jpg)
Then it was time to start on the joystick panels, since my optics, ir filters and special acrylic hadn't arrived yet. Yet again I did a cheesy mockup drawing of what I wanted.
![](http://i.imgur.com/cnEvhJ7.jpg)
After assembling the pieces it was time to find out where to drill the holes. Like everyone else these days I just ripped off the setup from the Tatio Viewlix joypanel. Template was downloaded from slagcoin and printed out without any adjustments on my Mac. If you wonder why I didn't center the stick in middle of the joypanel, there is a good reason for this. Your palms needs to rest on the panel or you will get tired really fast when playing.
![](http://i.imgur.com/BDq40L7.jpg)
![](http://i.imgur.com/3ZQgfrU.jpg)
I also got the metal panel made which is pictures under the parts used listing. After drilling the holes and test fitting buttons and an old hori joystick from an old PS2 stick, this was what the result looked like.
![](http://i.imgur.com/j7C2roo.jpg)
![](http://i.imgur.com/uVXZ0RF.jpg)
I then went to Filmteam A/S and got a artwork printout for the joypanel. Again I ripped off the Tatio Viewlix Panel and added the start button since I wanted a easy solution and a clean look
![](http://i.imgur.com/6WErhxK.jpg)
My new sanwa parts finally arrived and I mounted the JFL stick, joystick sleeves ect. This gave me the following result. However the pink buttons didn't really fit the clean and simplistic look I was going for.
![](http://i.imgur.com/v2pmq01.jpg)
