Author Topic: Vigolix bartop - M.Y. Arcade -- DONE!!! 2/6/2015  (Read 41677 times)
BorgDog
Re: Vigolix bartop?
« Reply #80 on: December 13, 2014, 07:44:19 pm »
Got it all wired up and tested it out to make sure everything worked and it did!  ;D
So put the bottom panel in place, just some scrap 5mm plywood held on by 2 little screws.
Actually attached the power supply (made from an old rack mount strip cut down to 2 plugs), the computer (gigabyte Brix celeron 2807), and the single usb powered speaker (was a Dell pair).  The speaker also has a little flat volume control that you can just see on the top edge of the speaker, nice and convenient.  The computer and speaker are screwed in from underneath.  At the top of this picture you can also see the butterfly catch that I mounted to hold the monitor in place for transport.  Forgive the bundled up power and vga cables, I am waiting for shorter versions to arrive.
I have decided on the following version of the control panel graphics and have started the process to get them from Brad (Lucian045) who did the fantastic Flynn's Arcade prints.  Of course that means I'll have to take all the controls out again.  Oh well, in the mean time I can play.
« Last Edit: December 13, 2014, 07:49:09 pm by BorgDog »
My Projects:
Rockhart
  • Last login:August 11, 2017, 02:15:04 pm
  • Game on!
Re: Vigolix bartop?
« Reply #81 on: December 14, 2014, 12:39:46 am »
I have decided on the following version of the control panel graphics.
Looks awesome  :applaud:
BorgDog
Re: Vigolix bartop?
« Reply #82 on: December 15, 2014, 10:00:50 pm »
A temporary marquee image pieced together from a couple pages of color laser printout, and plexi on the front for the display bezel, darn hard to take a picture of, very reflective oh and crappy phone pic  :dunno
My Projects:
BorgDog
Re: Vigolix bartop - M.Y. Arcade
« Reply #83 on: December 24, 2014, 04:29:44 pm »
I'm at the playable so not going to finish it mode... but I thought I'd share a pic of the grandkids playing at the cabin this weekend.  Amazing how a couple of 11 year olds take to playing the old games I used to play.  probably helped by the fact there is no internet or phone at the cabin :)
My Projects:
jaharr01
« Reply #84 on: January 25, 2015, 11:58:37 am »
Wow that's impressive where do you live Borgdog?
BorgDog
« Reply #85 on: January 25, 2015, 12:20:03 pm »
Thanks.  Still need to order the final artwork and get that applied, but I've already moved on to the next project so who knows when.  :dunno
I work outside Seattle, but "live" at the cabin, a couple hours north-east of there in the mountains.
My Projects:
TheDude
  • Bartops all the way !
    • BARTOPMANIA
« Reply #86 on: January 30, 2015, 05:39:25 am »
I didn't think it would turn out that good ! Impressed by the sleek look !  :applaud:
BorgDog
« Reply #87 on: February 06, 2015, 10:41:29 pm »
Feb 6, 2015 DONE!
Brad (Lucian045) printed up my simple graphics and I just got them put on today.  I'm calling it done.
The front overview.
The side view showing the Vigolix inspired design.
and the control panel.
And last but not least I'm going to attempt to insert/embed the first video I have ever uploaded to the youtubes showing how I rotate the monitor and how the Mala frontend handles it.
« Last Edit: February 06, 2015, 10:43:33 pm by BorgDog »
My Projects:
RetroGreg
Re: Vigolix bartop - M.Y. Arcade -- DONE!!! 2/6/2015
« Reply #88 on: February 06, 2015, 11:56:08 pm »
I like it. Great job!
« Reply #89 on: February 07, 2015, 11:10:51 am »
That sir is amazing. Nice job!
Louis Tully
« Reply #90 on: February 07, 2015, 11:17:34 am »
« Last Edit: February 12, 2015, 07:32:20 pm by Louis Tully »
Locke141
  • Never grow up.
« Reply #91 on: February 07, 2015, 02:01:58 pm »
 :applaud: This is a great little bar top.
I'd still like to try this on the laser cutter. What program did you do the plans in, and may I have them?
« Last Edit: February 07, 2015, 02:15:25 pm by Locke141 »
BorgDog
« Reply #92 on: February 07, 2015, 03:46:23 pm »
Thanks for the kind comments guys, this is definitely a fun hobby, working on number 2, planning number 3, each getting smaller, maybe someday I'll build a full size, but don't have room for one now.
Locke141 I did the design in sketchup (attached), it should be fairly close to reality although I did change a few things while building it, the back monitor support in particular I did not place until I had the whole monitor assembly built so I could get it all lined up right, and did not do the side rear notches until I got that placed.  The button layout changed a little to make it all fit, and I did an inset cover on the bottom of the control panel that is not in the design.
My Projects:
Locke141
  • Never grow up.
« Reply #93 on: February 08, 2015, 01:02:54 am »
Thanks man,
I was looking for this file:
http://forum.arcadecontrols.com/index.php?action=dlattach;topic=142115.0;attach=318843
The laser can only cut in two dimensions so the file I upload needs to be from a top down view. If you done have it no big deal I can make it in illustrator based on you pic.
BorgDog
« Reply #94 on: February 08, 2015, 01:10:25 am »
I do not have a cut sheet patter like that for the version i actually built.  That was pretty minimal, but I think I have it in sketchup as well.  see attached that has a couple versions I posted earlier.
My Projects:
