Author Topic: What size carriage bolts for controls?  (Read 1525 times)
IceCold
  • Last login:March 22, 2010, 05:11:22 pm
    • My MAME cabinet webpage
« on: December 11, 2003, 11:31:09 pm »
What size carriage bolts do you guys use for the joysticks, trackballs, etc. ?  I went to home depot, and they all looked HUGE compared to what I had seen used.
General Zod
  • Last login:June 23, 2005, 03:58:28 pm
  • Banned
Re:What size carriage bolts for controls?
« Reply #1 on: December 11, 2003, 11:58:13 pm »
That's right, the smallest HomeDepot carries is 1/4", which is way larger than you're looking for.
I would say a 10-24  2" bolt is your best bet, and you can find those at a local bolt/screw shop if you have one in your area.
Also , if that's not an option, another bolt you might want to use for a nice appearance is a Stainless or Chrome ButtonHead bolt. Those can be found at any Custom AutoParts shop.
« Last Edit: December 12, 2003, 11:53:07 pm by General Zod »
Ken Layton
  • Guru
  • Technician
« Reply #2 on: December 12, 2003, 01:03:29 am »
Commercial arcade games use 10-24 by 1" long carriage bolts for the joysticks mounted on metal control panels and 1-1/2" long ones when used on wood panels.
Trackballs mount with 10-24 by 3" long carriage bolts.
paigeoliver
  • Awesome face!
« Reply #3 on: December 12, 2003, 01:32:37 am »
My local hardware store has the correct game bolts. So skip home depot and try a normal hardware store.
Lilwolf
« Reply #4 on: December 12, 2003, 08:23:47 am »
I had the same trouble.  I couldn't find any long enought for my trackball.
I ended up using normal screws that came with a butterfly / flip open when you get them past the drywall screw kit....
BobRoberts has them pretty cheap.  I was waiting until my next order to get some real ones.
