Author Topic: Routing for T-Molding  (Read 6083 times)
mancity
  • Last login:September 01, 2014, 08:58:53 am
« on: July 30, 2014, 05:38:47 am »
Hi Everybody  :),
If im using 15mm MDF board for the said of an arcade cabinet, and I intend to T-Mold the edges, I understand I need to use a router for this, which my dad has.
Can anybody please tell me what router 'bit' I need to purchase to create the groove in the MDF?
Im not exactly sure of the thickness of the T-Molding piece which locks into the wood, but it looks around 3mm? so if that's the case, the router bit needs to leave 6mm, then gouge out a 3mm section?
I am not a wood-work person at all, so apologies if this question looks dumb.
Kind regards,
  • Last login:Today at 04:54:08 am
Re: Routing for T-Molding
« Reply #1 on: July 30, 2014, 08:13:02 am »
There are several different thickness bits, depending on the specific t-molding you are installing.
Most varieties require a 1/16" slot cutter, but some call for a 0.080" to 3/32" bit -- check the website you ordered the t-molding from.
If you can't tell for sure, post a link to the type you ordered.
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« Reply #2 on: August 08, 2014, 11:22:48 am »
The bits are usually available at the same place you bought the molding from.
lamprey
« Reply #3 on: August 08, 2014, 02:21:44 pm »
What you are looking for is a 3 Wing Slot Cutter Router Bit. There are many places to get them. I happen to have purchased a couple from MCLS and haven't had any issues. As PL1 mentioned you need to get the specs from the place you purchased to know what thickness of bit you need.
(see the 3 Wing Slot Cutter Router Bit section)
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html
  • Last login:July 16, 2025, 09:35:14 pm
« Reply #4 on: August 08, 2014, 02:46:38 pm »
There's a bit of this?  I always put on leather gloves and did it by hand with a hacksaw blade.
dubstylee
  • Last login:November 25, 2014, 11:01:07 pm
« Reply #5 on: August 22, 2014, 07:15:21 pm »
I have a quick question, I ordered some 3/4" t-molding from twistedquarter.com with some other stuff.  It says that the spine is 3/32" with the barbs, but they sell a bit that is 1/16" and says "use with 3/32" spine t-molding".  I plan on buying my slot cutter bit elsewhere, should I get a 1/16" bit, or 3/32"?  Here is the t-molding I purchased:
http://www.ebay.com/itm/120372350242
BobA
  • What Me Worry?
« Reply #6 on: August 22, 2014, 11:22:35 pm »
You need 1/16.  The slot has to be smaller than the spine so it will be griped tightly when the t molding is installed.
CaptainMarvel
  • Last login:May 03, 2020, 04:49:55 pm
« Reply #7 on: August 31, 2014, 04:59:04 pm »
Not sure if you even need this, but here are several video resources regarding cutting/routing for t-molding  . . .
« Last Edit: August 31, 2014, 05:01:08 pm by CaptainMarvel »
TOM
Understanding that you may not see success instantly, but that all your good decisions add up to a cumulative success over time is what separates those who "get there" and those who don't. Every day you either get further away from your goals, or closer to them . . . Its up to YOU."
