Author Topic: PC to Scart TV via USB2Gun interface questions  (Read 1672 times)
Jollywest
  • Last login:Today at 05:24:52 am
« on: June 29, 2014, 05:46:27 am »
... continued from Project Announcement thread here ===> http://forum.arcadecontrols.com/index.php/topic,138723.0.html
I'm hoping to connect a 25" Sony Trinitron KV-X2502U Scart/RGB TV to a PC via a USB2gun interface, as a temporary measure until I get a replacement Arcade Monitor.
The USB2Gun works with frequencies from CGA (15.75khz) upto XGA  (37.5khz). See page 4;
http://nanotechent.s3.amazonaws.com/support/OptiGun-User-Guide.pdf
Does this mean it can convert frequencies from VGA to CGA?
There is a set of Jumpers on the USB2Gun as well marked as CGA, EGA, VGA and Err. These are open by default.
If I were to set the jumpers to CGA and construct and connect this cable between TV and USB2Gun;
http://www.idiots.org.uk/vga_rgb_scart/index.html
Would this output the correct frequencies for the TV to display it?
I don't really want to try it unless I know for sure its not going to damage the USB2Gun board.
« Last Edit: June 29, 2014, 06:33:12 am by Jollywest »
