Author Topic: Sega Genesis Controller  (Read 6164 times)
BldnACab
  • Last login:May 11, 2010, 11:53:42 am
  • Doh!
« on: December 02, 2003, 12:14:17 pm »
I want to be able to connect an original Sega Genesis controller to my pc. (USB, parallel, whatever connection will work) Can anyone tell me whay my options might be. From what I can tell, I can not just connect it to my IPAC device.
Any help would be appreciated.
BldnACab
"Blue wizard has shot the food"
rockhopper
  • Last login:December 26, 2015, 05:15:36 pm
  • I love orange soda!
Re:Sega Genesis Controller
« Reply #1 on: December 02, 2003, 11:16:36 pm »
Try this site for all kinds of controllers to parallel port.
http://www.carneon.de/psx2pc/mirrors/www.csc.tntech.edu/~jbyork/manual/manual.html
i've yet to build one for my snes controllers but from what I've read they look promising
BldnACab
  • Doh!
« Reply #2 on: December 03, 2003, 08:57:57 am »
Thanks for the link.
Don't know if I can/will tackle something like this.
Anyone else have anything. Maybe something pre-made that I could buy.
BldnACab
HempHacker
  • Last login:July 28, 2004, 10:08:12 am
« Reply #3 on: December 08, 2003, 03:54:04 pm »
I've been working on a USB adapter for Genesis. I'm planning on selling a few that'll do SNES/NES/Genesis, but I've been out of town alot, so I haven't gotten everything together yet.
BldnACab
  • Doh!
« Reply #4 on: December 08, 2003, 06:57:05 pm »
Well let me know when you got one working. I will be interested.
BldnACab
HempHacker
« Reply #5 on: December 11, 2003, 10:28:47 am »
k, been out of town alot, but it should be done soon...
BldnACab
  • Doh!
« Reply #6 on: March 15, 2004, 02:27:53 pm »
Any progress on this or did the project die?
<BldnACab>
beek
  • Last login:March 22, 2020, 11:25:49 am
« Reply #7 on: March 15, 2004, 06:54:32 pm »
I modified two of the 6 button genesis pads to work with a keywiz.  If you can do a little soldering its not that tough.
I cut one end off a parallel cable and soldered the wires to each pad.  Then wired the other end into the keywiz.
There is a little chip on the board that needs to be removed.  I just used a dremel with a cutoff wheel.
$6.00 for the gamepads
I had the rest.
Zathras
  • Last login:June 06, 2011, 01:06:02 am
  • Yeah.
« Reply #8 on: March 16, 2004, 05:36:23 pm »
Retrozone now has a Genesis port to USB adapter
http://www.sealiecomputing.com/retrozone/
I recently got one from them but haven't had a chance to try it yet but I'm impressed with their nes and snes pads.
Space Warped by Someone
BldnACab
  • Doh!
« Reply #9 on: March 17, 2004, 08:07:52 am »
Thank you so much for the link. I ordered 2 last night.
BldnACab
Zathras
  • Yeah.
« Reply #10 on: March 19, 2004, 12:05:55 am »
Glad to hear I was able to help
and after posting I went ahead and tried it out and it works perfectly - though you have to reset the controls in gens.  The genesis controller was always a favorite of mine - It was the one I always used with my Amiga also.
The snes and nes emulators support multiple inputs so it works fine w/ control panel or if I plug in the controller.  Perhaps there is a way to get gens working the same way but I haven't found it yet.
The atari adapter works as well and z26 apparently accepts key inputs also but the fire button on the FE version is remapped to button two.
BldnACab
  • Doh!
« Reply #11 on: March 19, 2004, 11:45:10 am »
Just got them today. Hooked 1 up and I was playing in seconds.
Cool stuff.
Thanks again
BldnACab
GGKoul
  • Cheesecake Apprentice
« Reply #12 on: April 05, 2004, 02:49:07 pm »
Hey
Does anyone know if these Sega Genesis usb cables will work on a C64 joystick? Or do I have to buy an Atari cable as well?
-GGKoul
Zathras
  • Yeah.
« Reply #13 on: April 05, 2004, 03:23:53 pm »
that is an interesting thought - the Atari one does list Commodore and Amiga and I always used the Genesis controller on my Amiga (they didn't have that listed when I ordered the first set)
I'll try that out when I get home :) (actually it would save me money because I was contemplating ordering another)
GGKoul
« Reply #14 on: April 06, 2004, 01:34:21 am »
Any update?
Zathras
  • Yeah.
« Reply #15 on: April 06, 2004, 03:00:04 pm »
There would be but I forgot - I just wrote it on my hand to check tonight :)
Zathras
  • Yeah.
« Reply #16 on: April 06, 2004, 10:37:10 pm »
Ok I tried it - and you need both.  It kinda sorta works but the button mapping is different.
On the genesis controller plugged into the atari adapter up, down, left, right and buttons b and c worked - nothing else.
MaLarryA
  • Newbie
  • Last login:April 09, 2014, 05:55:20 pm
  • What good's a reward if you ain't around to use it
« Reply #17 on: April 26, 2004, 05:46:50 pm »
I am wondering -- since there are Nintendo and Sega to USB converters, does this mean I can get a USB to XBOX converter and use a Genesis controller with the XBOX?
Gotta love that!
MaLarryA
dvdapex
  • Last login:August 21, 2006, 05:16:42 pm
« Reply #18 on: June 10, 2004, 11:06:21 am »
http://dawgslair.com/joypad/joypad%20hack.html
Shows how to hack a Genesis 3 button to interface with an IPAC.
me333333
  • Newbie
  • Last login:June 30, 2004, 07:32:35 pm
« Reply #19 on: June 30, 2004, 07:47:42 pm »
I don't know if anyone noticed this before, but the genesis controller plug end exactly matches the plug of a standard 9-pin serial port.  So, the genesis controller can actually plug directly into the back of any pc without modification.  I was wondering if anyone knows of a driver for a regular genesis controller, or if it is even possible to make one to connect the controller directly.  If it is possible, perhaps one of you geniuses can work on creating one.  Thanks.
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
« Reply #20 on: July 01, 2004, 10:47:59 am »
Uh, just cuz the plug is the same, doesn't mean that it can work. A serial port is RS232 communication, the genesis pad is straight up digital logic. No way, with out some protocol chip between the two, could you get it to work. Just cuz the key fits inside the lock, doesn't mean it will turn....
Call the locksmith!
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
Adeptus
  • Last login:May 31, 2006, 11:25:07 pm
  • Putting the 'Mad' back in (computer) science
« Reply #21 on: July 22, 2004, 03:28:50 am »
I think you're trying the reverse of what he asked... you're plugging the Genesis pad into the Atari convertor. So, not surprising only a couple of the buttons work as Atari sticks only had a couple (well usually 1).
From what you say works, my guess is the Atari stick in the Genesis convertor would work, but the button would act as either B or C.
Of course, to find out for sure you could email the guy. I asked him a couple questions & he got back to me pretty quick.
daroga
  • Newbie
  • Last login:July 26, 2004, 04:24:00 pm
« Reply #22 on: July 26, 2004, 04:25:01 pm »
I emailed the RetroZone guy to ask if the Atari stick in the Genesis adapter would work.  Has anyone else given this a shot since it was last talked about?
daroga
