Author Topic: DIY Air Hockey Table??  (Read 7262 times)
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« on: November 30, 2003, 05:06:00 pm »
Anyone ever tried to make an air hockey table?  A friend of mine (a woodworker and electrical engineer) asked me the other day if I ever came across plans for a DIY table, and so far I havent.  Anyone tried this, or can point me in the right direction?
NiN^_^NiN
Re:DIY Air Hockey Table??
« Reply #1 on: November 30, 2003, 05:46:43 pm »
Actully i do know of plans but i dont remember where they are tho :(
I'l search for you when i get home but what i remember is all you need to do is evenly drill holes over the playfield and you use a lef blower (you know them things u use to blow leafs away) as the air pump.
i'll find the plans for you later ok :)
but another alternative is to buy a self powered air puck they are big but its cheaper and all you need to make is a table no holes nothing :)
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #2 on: November 30, 2003, 09:23:50 pm »
old thead about byoat
repair air hockey info
another thead
*Shrug* hope that helps.... goodl uck!
rampy
Ken Layton
  • Guru
  • Technician
« Reply #3 on: December 01, 2003, 12:23:57 am »
A leaf blower? For the air blower.....you've got to be kidding! That would be awfully LOUD!
 Generally the commercial coin-op Dynamo air hockey (and it's predisessor the Brunswick) use a Grainger blower assembly and commonly available furnace filters for the air system.
NiN^_^NiN
« Reply #4 on: December 01, 2003, 12:54:22 am »
Yeah they said leaf blower altho id use that keaf blower to make my own hovercraft :D
but yes im sure there is better and less noisy solutions :)
He did ask about the a DIY table and i just mentioned what i saw awhile ago :)
but rampy actually posted the build your own air hockey table 2 post up :) so check that out
also check this out for a bit of fun ;) how to build your own human air hockey puck :D its a homemade hovercraft as i mentioned above but the www.howthingswork.com has better instructions on how to build 1
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #5 on: December 01, 2003, 11:55:30 am »
What did you search for?  nothing comes up when you search for hovercraft.
electricd
  • I'm not a llama!
« Reply #6 on: December 01, 2003, 09:03:07 pm »
hey Ken:
any idea how large of a grainger blower should I need??  There are sooo many of them on thier site!
ED7
Ken Layton
  • Guru
  • Technician
« Reply #7 on: December 02, 2003, 02:28:21 am »
No, I don't know what size/type offhand, but if someone could get inside a Dynamo air hockey and get the numbers off the Grainger blower motor nameplate it would be a big help.
NiN^_^NiN
« Reply #8 on: December 02, 2003, 05:52:29 am »
hey sir poonga long time no see :)
http://travel.howstuffworks.com/hoverboard1.htm
its really cool and works ;)  ;D
